Question about Boating
It freezes but won't stop
Freezer is working and freezing below 30 degrees however the fan is continuously running for hours and hours.I won't stop. Thermostat issue? How easy is to replace it?
    Champion:
    New Friend:
  • 227 Answers
As long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Posted on Dec 19, 2013
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Aug 24, 2011 | Kelvinator Freezers
It's a Viking freezer, not refrigerator. I know it is an older model but I don't know the model number. Ice forms on the coils on top of the freezer and the temperature inside the unit rises to...
VCBB363SS is a refigerator on top with a large door that opens and has a pull out drawer below that is a freezer
25 is too warm for freezer section
are coils snowed over complete or just on top 2 passes
if snowed solid defrost problem
if only snow on top fc fan is not running or system low on charge low side leak
unrelated if your mod is correct there is a hinge recall that should have been replaced
May 30, 2017 | Viking Professional VCBB363SS Stainless...
Freezer is freezing about 25 degree,but the ref. will not get below 40 degree.
It's quite normal if freezing is not reach on 40 degree, it's already high temperature. Remember the lower the temperature setting the higher the freezing of refrigerator, the higher the setting the lesser the freezing.
It's simple as that friend. Good luck!
Jun 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing - can hear a clicking noise coming from areond the th.ermostat / motor area
My freezer has a light that says "high temp" but the freezer isn't freezing my products.....what can I do? It also says that the temp has been 23 degrees or higher for more than 1 hour. I really don't think that the problem is being in hot weather
Apr 22, 2011 | Freezers
The 2 fans are not working but the freezer coils are freezing up won;t go below 20 degrees
the freezing is and temp are caused by the fans not working. One fan pulls warm air out of the box and across the evaporator coil, which in your case is frozen, and the other fan is used to pull air over the condensing coil which rejects the heat pulled out of the box. check the wiring diagram for a fan relay first, which can easily be changed out, or by some crazy chance, both fans quite working at the same time
Nov 20, 2009 | Freezers
Kenmore Side by Side not getting cold enough to freeze food.
Evap fan...cond..fan ...do they turn.....seems like a comp...problem...does the evap ice up...?
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
