Question about Hotpoint Dryers
Need Wiring diagram for a hotpoint tvm50 aquarius tumble drier door and control panel
Need guidance on how to get the wires back in, some came loose as I fixed a new belt
  • diamante Jan 11, 2013
    hello folks, I have taken a picture and created a diagram that shows the problem i describe above and would appreciate assistance from any skilled/learned person.
4 Suggested Answers
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
SOURCE: help with door switch wiring.
Just found that my neighbour works for comet
Got full PDF. Whiring is as follows:-
3=Gray
4=Brown White
5=Pink White
Posted on Dec 31, 2008
godtech
  • 51 Answers
SOURCE: i need a wiring diagram for a hotpoint tumble dryer model vtd00
CALL 1-800-626-2005 ALSO CHECK THEIR WEB PAGE WWW.HOTPOINT.COM
Posted on Jan 16, 2009
The wiring to my hotpoint tumble dryer
You would have had to disassemble the dryer to replace the belt, so the video was correct. The door switch assembly wiring at the front of the dryer mates with a matching connector which you would have separated for cabinet removal. Don't know why you messed with control panel wiring for belt replacement but you can go to www.repairclinic.com and enter tcym 750c to see a list of common replacement parts and maybe a video showing disassembly of a generic Hotpoint dryer. You might be able to get an answer to your wiring question.
Aug 10, 2016 | Hotpoint Dryers
I need a wiring diagram for a hotpoint TVF770 tumble dryer. I've replaced the heater element and want to confirm where I plug in the wiring loom. Thank you for your help.
I am sure if you go on line and ask for
diagram or manual you will get it. Or go to
Hotpoint and it will be on site once you have
chosen the tumble drier you have.
Next time you do a job like that always make
a diagram of what you are doing.It pays every time.
LUCK
Sep 25, 2014 | Dryers
THE WIRES MIXED UP ON MY TUMBLE DRYER HOTPOINT VTDOO TIMER
In most appliances I've had apart there is a stick plasic envelope stuck somewhere inside the cabinet or the control panel that contains the wiring diagram.
Nov 24, 2013 | Hotpoint Dryers
My hotpoint aquarius tumble drier is making a very lound griding sound as it turns. What can it be and can it be repaired by myself? the drier is over 8years old is it time for a new one?
This is the plastic "wheel" on the motor that drags the drive belt to spin the dryer. you will need to push back into place with something thin. under the right hand side of the dryer there will be a grill under the motor. look for a black plastic "wheel" and move it away from the casing with something that can fit through the grill.
May 16, 2010 | Dryers
Dear Sir I need a wiring diagram for a Hotpoint Aquarius washing machine as have lost notes on disconnection. Thanks Paul
did you open the control panel up? inside the control panel there is usualy a wiring schematic.... otherwise i need the model # which should be located onthe backside of the machine or sometimes under the lid, in the back....
Oct 21, 2009 | Washing Machines
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
How do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
Jan 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dryers Logo
475 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
