Question about HP Compaq ProLiant ML350 G5 Server
ML350 G5 motherboard first processor socket has pin damage. Can I use second processor socket on its own and if so how?
I do have a PPM module to use with the second processor socket. Other than that no further relevant details
  • Mike Jan 13, 2013
    Its an HP Proliant server with dual CPU capability. The PPM for socket 1 is built in to the motherboard, but that for socket 2 is a separate card.
    Sergeant:
  • 378 Answers
Tell it to run off solo prcosasesro in bios
Posted on Feb 05, 2013
How to physically replace the power supply connector that is soldered to the motherboardon the right side of the memory modules
itis possible but you need to solder it on again without making a conection with other component so rather take it to the pro
May 11, 2013 | Gigabyte GA-890GPA-UD3H Socket AM3/ AMD...
What kind of RAM memory uses this motherboard
Gigabyte GA-5SMM - motherboard - micro ATX - Socket 7 - SiS530 specifications
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory L2 cache - 512.0 KB
  • Chipset Type SiS530/5595
  • Max Bus Speed 100.0 MHz
  • Processor Socket Socket 7
  • Compatible Processors 6X86 , Cyrix MII , WinChip 2 , WinChip C6 , K6-III
  • Memory
  • Max Supported Memory 256.0 MB
  • Supported RAM Technology SDRAM
  • Supported RAM Integrity Check ECC
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x PCI - Socket 7 , 3.0 x Processor - DIMM 168-pin , 3.0 x ISA , 2.0 x Memory
  • Storage Interfaces ATA-66 - connector(s): 2 x 40pin IDC
  • hope this helps
Aug 13, 2011 | Gigabyte GA-5SMM Motherboard
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
What are the parts of the motherboard?
1) Let's start with the 'Brain'. The Processor:
The Processor sits in a Processor socket on the motherboard.
The socket will match the particular Processor that is used.
On the older computers, the different Processor manufacturers often used the same type of processor socket, for their Processors.
As computer technology evolved, the different processor manufacturers started using a processor socket that only matched their particular Processors.
Now only AMD processors will fit in an AMD processor socket.
Same for Intel, and the same for VIA.
2) Ram Memory:
Ram Memory comes in a Module. Often referred to as 'Stick'
The Ram Memory modules sit down in a ram Slot.
Correct computer speak is Bank. Each slot is a Bank.
Ram Memory modules are specific in the number of contact pins on the bottom of them.
(Gold plated contact pins)
SDR Sdram, often just referred to as Sdram, has 168 contact pins. 82 on each side.
(Single Data Rate Sdram {Sychronous Dynamic Random Access Memory)
The bottom of the ram memory module also has Two Locating Notches.
DDR Sdram has 184 contact pins. 92 on each side. One Locating Notch
DDR2 Sdram has 240 contact pins. 120 on each side. One Locating Notch
DDR3 Sdram has 240 contact pins. 120 on each side. The Locating notch is in a different place than the DDR2 Sdram ram module.
3) Expansion slots:
An add-in card is a small circuit board. This can refer to a,
A) Graphics Card, (Graphics Adapter Card, or also known as Video Adapter Card)
B) A Modem Card (Again, > adapter has been dropped off)
C) A Sound Card (Audio) {Adapter has been dropped off)
D) Ethernet Card
Or a number of other technologies used.
The add-in card is inserted into the appropriate expansion slot.
4) Motherboard Chipset:
Chip and Chipset are slang terms for I.C.
Integrated Circuit.
The motherboard chipset consists of the Northbridge chip, and the Southbridge chip.
[NOTE*
This does not apply to new technology used for the Intel Core i3. i5, i7, and i9 processors ]
The Northbridge chip handles the faster capabilities of the computer
The Northbridge chip supports;
A) What Processor is used.
B) What Ram Memory is used
C) High-speed graphics.
{High-speed graphics is considered to be AGP, or PCI-Express. Not a graphics card inserted into a PCI slot, nor Integrated Graphics }
The Southbridge chip supports the slower capabilities of the computer.
D) Any add-in card inserted into a PCI slot
E) Integrated Graphics
F) IDE (PATA) and SATA harddrives
G) USB ports
H) Data coming from the Super I/O chip, and it's associated hardware connected to it.
(The Northbridge chip is connected to the Southbridge chip by the Front Side Bus. {FSB}
Think of the FSB as an 'Information Highway'.
Data {Information} is transferred to the Northbridge from the Southbridge, and to the Southbridge from the Northbridge, via the FSB.
The Southbridge chip is connected to the Super I/O chip by the Internal Bus.
Motherboard Diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short. It Does Not refer to the computer as a unit)
This shows a typical motherboard, and refers to the different parts of it,
http://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svg
I invite you to type the following terms in the search box on Wikipedia, and learn more about the parts of the Motherboard, and the technology of the different parts of the motherboard, and the associated hardware that goes on the motherboard,
1) CPU socket
2) Bus (computing)
3) Expansion Card
3) AGP
4) PCI Express
5) BIOS
6) Northbridge (computing)
7) Southbridge (computing)
8) GPU
9) Harddrive
10) Sata
11) Integrated Drive Electronics
12) Motherboard
Also click on any word, or term in blue in the page/s, and click on the links at the bottom.
This may help to understand the different parts of a Motherboard, (Mainboard), also,
http://computer.howstuffworks.com/motherboard.htm
Nov 22, 2010 | Computers & Internet
Can I upgrade Celeron -D 2.26Ghz to the same mobo ie. E219882
Intel E219882 motherboard, also know as Intel D850GB?
No.
1) The motherboard has a Socket 423 processor socket.
http://en.wikipedia.org/wiki/Socket_423
This processor socket has the socket holes, while the processor has the pins. Has 423 socket holes.
The Intel Celeron D 315 uses an LGA775 processor socket.
LGA775 is also known as Socket T. Has 775 pins in the processor socket. The processor used has the socket holes. 775 of them.
Celeron D 315 spec's,
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#Celeron_D
2) The Intel D850GB motherboard only supports Single Core processors. Not Dual Core like a Pentium D.
Must be an Intel single core processor, that fits in a Socket 423 processor socket.
Intel only made processors to fit the Socket 423 for about 2 years. Intel had a deal with Rambus, for memory to fit Intel's motherboards, for this period of time. The deal fell out, and Intel moved on.
The Intel D850GB motherboard Only uses RIMM memory modules, ('Stick/s') made by Rambus.
(RIMM. Rambus Inline memory Module)
Highly expensive, overrated ram memory.
Intel D850GB motherboard specifications,
http://www.intel.com/support/motherboards/desktop/d850gb/sb/cs-013247.htm
On this page go down to -
Product Specifications [PDF]
in blue, and left-click on it.
After you click it may take a few seconds for the PDF file to show.
Sorry to be a bummer, but wanted to give you in-depth info about your motherboard.
Have any additional questions, please state so in a Comment.
Jan 17, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Number of pin in mother board number of teeth in mother board number of transitor
This sounds like a Processor question. Perhaps delving with how many pins are in the processor socket, on the motherboard.
Also how many transistors are in the processor.
There are presently two styles of mating up a processor in a processor socket.
1.The processor has the pins, and the processor socket on the motherboard has the holes, (Socket holes)
2.The processor socket has the pins, while the processor has the socket holes.
Your question looks like it deals with the style whereby the processor socket on the motherboard, has the pins.
Here is information about the various processor sockets, and also slots, plus information about the various processors.
Processor Sockets and Slots
A.http://en.wikipedia.org/wiki/CPU_socket
In the ->List of Sockets and Slots chart, in the column on the left side, you will see Socket's named, as well as Slots. These are in blue. If you click on them you will be taken to a page that has more information on it.
Processors, (Microprocessors)
B.http://en.wikipedia.org/wiki/List_of_microprocessors
Again, you click on anything you see listed in blue, and it is a link that takes you to more information.
As you click on a link that has general information, you will also see other links in blue on the page, plus links at the bottom of the page. These will take you to more specific information about the processor you're looking at. There you will see,
1.How many transistors it has
2.What the Front Side Bus is. (Frequency Rate)
3.What Frequency Rate the processor operates at. (Slang is Speed)
4.What size the cache is in MB. (L2 cache. The L1 cache may be listed, as well as the L3 for the newer processors)
5.What the Voltage range is.
6.How many Amps the processor could use while operating at full capacity.
Plus a lot of other info.
Sep 17, 2009 | HP Processor Board A6153-69001...
HP Compaq ProLiant ML350 G5 Server Logo
155 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
