Question about Dell Latitude D600 Notebook
Dell gx520 power light flickers green and cant powerup
  • aondes Feb 08, 2009
    I have the same issue with a D600.
    When trying to turn on, lights flicker (~5 sec) then nothing.
    Same iisue in our out of dock.
    No change when all components (HDD, CD, RAM) are removed.
    Any thoughts?
    Champion:
  • 203 Answers
Rmove the baterry and start without baterry, and put back the bateryy after restart .
Posted on Jan 22, 2009
    Scholar:
  • 62 Answers
HI,
If your laptop runs when you plug and does charge your battery, then your battery is not working. If you have your warranty, go for a change in battery.
If it doesnt work even when its plugged, then your motherboard is not recognizing the battery or power card. So call dell for assistance regarding that.
~regards,
Jegan
Posted on Jun 02, 2009
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
Orange light
A solid amber light means you have an internal power problem. Your power supply has probably died.
May 19, 2012 | Dell Gx-520 Intel Pentium 4 2.8Ghz Desktop...
Dell Optiplex gX520 will not boot beyond the splash screen. Dell Optiplex gX520 will not boot beyond the splash screen. There are not post code beeps.The lights on the front panel are 1 and 4. Both are...
Sounds like you may have multiple problems. Suggest trying to eliminate possible causes by removing components. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Remove the components one at a time and see if the LED's change.
Dec 10, 2011 | Dell Optiplex GX520 Desktop PC - Intel...
My GX520 was shut down as usual last night...I turned on this morning and I get nothing...just a little yellow/amber light blinking where it is normally green....help
Here is the info straight from Dell. looks like you have an internal power issue. You will most likely need to contact Dell directly for assistance, they are pretty good about giving support even if the system is no longer covered under warranty.
If the power light is blinking amber -
The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Dec 28, 2010 | Dell OptiPlex GX520 PC Desktop
When i go turn on my dell optiplex gx520 all I get is a flashing yellow light instead of a steady green light. I have checked power supply and reseated all devises with no luck.
checked replacing ram and the motherboard that should fix ur problem or else try booting ur system without modem card plugged it and also by pass surge protector .
Oct 29, 2009 | Dell OptiPlex GX520 PC Desktop
Unable to upgrade onboard graphics on dell gx520
Try disabling your onboard graphics in the BIOS. Some BIOS allow this. If you have a sound card, disable the onboard sound too. Count your beeps. they contain a code. Go online and "Google" bios codes. This should give you a starting point to diagnose the problem.
Oct 10, 2009 | Dell OptiPlex GX520 PC Desktop
The power light comes on as orange
REMOVE board from cabinet then check you can easily track the problem
Feb 07, 2009 | Dell OptiPlex GX520 PC Desktop
I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Aug 20, 2008 | Dell OptiPlex GX520 PC Desktop
Dell Latitude D600 Notebook Logo
414 people viewed this question
Alun Cox
