Question about Breadman Tr2500bc Ultimate Plus 2-pound Stainless-steel Convection
Breadman ultimate bread won't rise
Every time i try to make bread in this machine, it doesn't mix the ingredients together well, and bakes to about half the size it should be. i'm debating throwing it out and buying a different one.
  • 691 Answers
Ensure you are using the right ingredients, fresh yeast, a little salt and maybe a crushed vitC tablet. Don't use standard fine flour you need a courser flour. help it mix by putting ingredients in evenly, liquids first. melt any butter you use in a microwave before adding. most breads use artificially improved flours. if you grind your own flour it will end up a much heavier loaf.....i like it that way.
If nothing i have said helps then it might be time to give up on your breadmaker
Posted on Jan 11, 2013
3 Suggested Answers
  • 56 Answers
SOURCE: The bread did not bake. The ingredients mixed,
You may have a bad heating element. If this is the case it will be hard to find that part.
Posted on Dec 08, 2009
  • 10865 Answers
SOURCE: We are using the
Hello roger...... It is vitally important to be using fresh ingredients since the yeast will deteriorate as time goes on. Go to the store and buy a fresh bread mix to see if that is the problem. If it works as it should great, if not then you have a more serious issue within the workings of the machine itself, most likely the timer. Joe
Thanks for choosing Fixya!
Here is a free download of your breadman manual in case you need one.
http://www.devicemanuals.com/guide/Bread%20Machine/Breadman/Breadman-TR2200C-Breadmaker-Instruction-Manual-==TXpVeU9UazU=.html
Thanks for choosing fixya!
Posted on Dec 04, 2010
Why does my bread continually fall in baking cycle
i use reg yeast ~~ my machine doesnt rise long enough so i use it just to mix the ingredients and do the 1st rise --i take it out before the final rise and raise it in a bread pan myself and bake it to 195 degrees
ALL baked goods should be baked to a specific internal temp!!!!!!!
Checking the internal temperature of bread is a foolproof way to tell if it is fully baked. Insert an instant-read thermometer through the side of the loaf and the internal temperature should be 190 to 200 degrees~~cakes about 210
Jul 17, 2014 | Breadman BK2000B 2-1/2-Pound Bakery Pro...
Health start
If you have a bread machine you can buy the ingredients at any grocery store in the baking aisle. Most stores even have the premade bread machine mixes.
Nov 08, 2013 | Breadman Kitchen Appliances - Others
Breadman ultra tr700 did not bake the bread
The whole process takes 3-4 hours to complete. Did you give it that much time? Next time note how many hours are on the readout just before you push "START" and let the machine countdown to 0:00 on the clock before you assume something is wrong. If you did that last time and the bread wasn't baked then your machine is broken.
Feb 10, 2013 | Breadman Kitchen Appliances - Others
I baked a bread and now its uncooked how do i set the timer for more time to bake ONLY please help me quickly
There will be no need to extend the baking time on your uncooked loaf for if the loaf is uncooked as you say cooking it longer won't make things any better. I suspect you need a bit of tutoring regarding the fine art of using a bread machine.
Here is the assistance I offer:
White Flour: When using white flour select nothing less than unbleached white flour containing 12 to 16% protein (or 3 to 4 % per ¼ cup serving). Storage: Flour absorbs ambient humidity hindering it from blending with liquid ingredients during the initial kneading phase so always be certain to store your flour in a burped & sealed freezer bag.
Yeast: Use active dry yeast for all your standard-rise bread recipes and rapid-rise dry yeast for all your fast-bake bread recipes. Fast-Bake aka Ultra-Bake aka Rapid-Bake aka Express-Bake is an option available on select models. Always refrigerate your yeast with a close eye on the expiration date. When using grocery-bought bread mixes always substitute the yeast packet provided with fresh active dry yeast. Tip: A packet (or "sachet") of active dry yeast contains 2-1/4 teaspoons.
Baking Surface Prep: Spray, not wipe or smear, the inside of your loaf pan generously with cooking oil before adding the ingredients.
Water: Use only drinking or filtered water, never tap, boiled or distilled.
Ingredient Temperatures: All ingredients should be at room temperature before pressing Start. Specifically 70 to 80 degrees F, 21 to 87 degrees C. Add liquids, oils, salts, sugars and seasonings first, next the flour, and last the yeast.
Delayed Start: Flour floats on the surface of the water until the initial kneading phase begins. That is why many breadmakers have a programmable start-delay timer. You can add the ingredients tonight and wake up in the morning to the aroma of fresh-baked bread.
Shelf Life: Refrigeration and/or freezing finished loaves is not recommended. For best results store them in a breadbox. Tip: Adding 1-2 tsps of lemon juice to any bread or dough recipe will double the shelf life of your bread.
Measuring: Water MUST be measured using a clear liquid measuring cup. Dry ingredients MUST be measured using standard measuring cups. All measurements, either spoons or cups, MUST be leveled.
Slicing The Loaf: Electric carving knives work best, especially when using a slicing guide. Be certain to wait until the loaf is cool to the touch before slicing.
Did this answer help? Please rate this answer as soon as you can. Thank you.
Jun 08, 2011 | Toastmaster Kitchen Appliances - Others
Oster 5834 not mixing ingredients well before rising & baking
Take the bread pan and paddle out of the machine and see if you can spin the paddle by hand. If it moves freely, then it could be the belt is loose on the pulley inside the base of the machine, or the pulley or motor itself is not right. Either check the belt or exchange it at the store or check warranty. It is obviously a defect. Good Luck, Hank
Jan 20, 2010 | Oster 5834 ExpressBake Bread Maker
Oct 18, 2009 | Breadman TR845 Bread Maker
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
I have a Breadman Ultimate and use a gluten free recipe. It baked beautifully but after it cools there is a big air hole in the middle. Any suggestions?
Here's a solution from my wife: After the last mix in the cycle, remove the dough and place it in small bread pans and bake in the oven. She had a bread machine that mixed well, but the baking part of the machine was less than great.
Worked great for us!
k
Sep 04, 2009 | Breadman Kitchen Appliances - Others
Doesn't bake
Our machine is 4 years old and works well. However, our breadpan is leaking. We can't find another. If you would like to purchase the machine, we would be willing to sell it.
MikeBrinx@att.net
Jul 22, 2009 | Breadman TR2200C Ultimate Bread Maker
Kneading
Check your measurements.
Sounds like operator error.
Dec 12, 2006 | Breadman TR2200C Ultimate Bread Maker
Breadman Tr2500bc Ultimate Plus 2-pound Stainless-steel Convection Logo
104 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
