Question about Maytag Neptune MAH7500WH Front Load Washer
Hotpoint WD860P F5 error
After removing 17p and a couple of hair bands - the water will not drain unless I put the hose in a bucket (lower than the drum i think)
Any ideas of asistance.
Thanks in advance
  • Mozza1 Jan 22, 2009
    thanks for the advice, however the small panel at the rear bottom of the machine is this the part that connects to the waste pipe?
    if not could you point me in the right direction or advise where i can get a manual with diagrams so can follow.
    Many thanks
    President:
  • 373 Answers
F05 - Pressure switch jammed on full.
The pressure switch needs testing and possibly replacing unless this is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.You can sometimes test them by blowing into the part where the pressure tube goes, but only blow gently. You should hear it click when you blow into it.
Good luck with the machine.And for further doubts please do post comments.
Posted on Jan 22, 2009
  • Suresh Thrithandam Venkata Lakshmi Narayana
    Please try the following link and tell me whether its the same model.It has the internal diagrams that might help you disassemble.I can provide more in case this is not sufficient.Also please do rate my solution if accepted.
    click here for internal diagrams
    Am sorry will find the right link, the one i gave is for a maytag neptune washer model under which you have posted the problem.Sorry again.Will get you the right link when i find one.
Hi what error F5 means in a white whale dishwasher ?
The F5 code means that the machine is not draining. Either there is something blocking the drain line or the drain pump is defective. I would first check the outlet where the drain line atttaches to. Take the drain ho9se off the syphon gap or trap and see if the water will drain out of the machine into a bucket. If it will you need to clear the trap or syphon gap where it connects to. If it will not there could be something jammed in the drain pump or the drain pump on the machine could be bad. You would have to remove the lower kick panel and access the drain pump where the drain hose connects to get it out and check it for damage or obstructions.
Nov 02, 2016 | Dishwashers
My dishwasher won't empty
This condition is commonly caused by:
- Drain pump jammed
When you wash your clothes, any small objects (e.g. hair pins, coins etc) are flushed down the drain pipe but often get jammed in the drain pumps impellar (this is the tiny propeller on the pump).
Firstly, place a bucket on the floor....then lower your drain hose (from your tub) into the bucket - the gravity will naturally drain the water into the bucket. Be careful to raise the hose and empty the bucket each time, until the machine is empty. Remove any wet clothes from machine (you will need the bowl to be emptied).
Once empty, you can now check the drain pump.
Turn the machin off at the power.
Locate the drain pump cover (usually near the drain hose, on the back or side). Place a large towel on the floor beneath the pump cover (as remaining water will escape onto the floor). Unscrew the drain pump cover and allow the water to drain (if your pump cover contains a filter, then clean everything from this filter).
Then, look inside the drain pump cavity for anything obstructing the little propeller (remove any objects). Insert your finger inside the cavity and rotate the little propeller - you should feel a resistance, similar to a rubber band.
Re-install the drain pump cover (or filter) and ensure it is sealed properly. Turn ON at the wall.
Fill your bucket with water (from tub) and pour into your machine.
Turn machine ON, and select the last SPIN (or drain) cycle and check if machine now drains correctly. If ok, then problem now solved and you can put the clothes back into the machine for a final rinse/spin.
If machine still not draining after inspecting the drain pump, then you may have a suspected faulty drain pump - a technician can run a diagnostic process on your machine's control pad to find the diagnostic codes.
Please do let me know, if the above process helps you solve this.
Cheers,
Oct 02, 2011 | Dishwashers
My hotpoint washing machine is showing error code F05
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved.
Hope this helps... Please post back for further assistance.
Daniel
Apr 18, 2011 | Hotpoint Washing Machines
Hotpoint ultima wt640 am getting a flash code f-05 clothes still wet appears not to spin
Hi Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps... Daniel
Mar 26, 2011 | Hotpoint Washing Machines
Hi got hotpoint aquarious wmf740. all lights flashing f-05 ? wont spin or drain. please help
Hi
Daniel
Aug 30, 2010 | Washing Machines
I have hotpoint aqurieus WML560 will not drain how do i do this manualy
To get rid of any water still in washer, lay drain outlet hose to floor level, and the water should run out through gravity into a bucket or similar.
Once empty, remove the lower rear pamel of washer.
Remove large black hose on to pump.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Will not pump out
Remove lower rear panel of washer. Lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
Locate, and remove large black hose on bottom of tub. Remove plastic filter inside, and clean. Check pump also. Refit filter and hose.
Plz rate if helped.
Apr 04, 2009 | Hotpoint Aquarius WD640 Front Load...
F 18
Plz rate if helped.
Mar 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD860P - F5 error
Remove lower rear cover of washer, locate and remove large black hose to bottom of tub.
Remove and clean plastic filter located in the hose, check pump for blockage, refit filter and hose , and test for leaks.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
321 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
