Question about Haier Top Load Washer
Haier rwt350aw super capacity washer not spinning
The water drains, but does not spin
  • 4 Answers
SOURCE: draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Posted on Jan 22, 2009
GodBlessU
  • 3513 Answers
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Posted on Oct 13, 2009
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
heatman101
  • 43501 Answers
SOURCE: haier XQB40-F water will not pump out
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
BIKER T
  • 909 Answers
SOURCE: Haier HWc1460tve wont enter spin mode, water pump
check the sensor that normally is attached to the motor. If it has come loose, speed becomes erattic .If good, suggest brush check as well.
Posted on Sep 08, 2010
sonicboomele
  • 1557 Answers
SOURCE: I have a RWT350AW washer
if it is still washing then your not in real trouble in most cases the problem is to do with your water pump have hubby take the hoses of and see if any tubes are blocked if not see id=f the water pump is turning if not replace it then you should be right as water pumps often fail within months as to poor line production in some cases
Posted on Sep 29, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Washer will not drain or spin clothing
Old post but its the pump thats blocked.the drum is programed to spin as the water lvel drops via pump
Jul 23, 2014 | Haier RWT360BW 3.0 Cu. Ft. Capacity...
Water does not drain during spin cycle. Tub spins, but water remains in the tub.
Water pump is out. Will need a new pump.
Only other possibility is your drain hose is clogged check that first.
Drain Pump Part #: AP5684706 Runs about $95:
Frigidaire 137221600 Drain Pump AppliancePartsPros com
Apr 18, 2014 | Westinghouse WWS833ES Super Capacity Top...
Is it normal for liquid to be present in the top part of the drum?
Yes I have this type of washer and it has the water in a ring at the top of the drum to help balance it out during spin, not quite sure why but yes it should be there. The gargling sound you describe could also be the balancing hooks that attach the drum to the top of the washer which sometimes make strange noises but there fine.
Mar 10, 2013 | Haier RWT350AW Top Load Washer, White, 3.0...
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
My washer dont drain water and don spin but aggigates.please help
your washer house is to low it has to be sink level or 90 dgree angle for it to drain after drain it sould go in faze mode to spin if not your belt is bad.
Feb 06, 2011 | Westinghouse WWS833ES Super Capacity Top...
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Haier Top Load Washer Logo
53 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
