Error 80070005 always says windows is critical needs to shut down
  • Jack Iaria
    Jack Iaria May 11, 2010
    When you say 'critical' what do you mean?
    Problem Solver:
  • 8 Answers
Your computer has a virus
Posted on Jan 22, 2009
Error 80070005 windows update
Start your computor under safe mode, then try start windows under last known.... If that doesn't work. Again Start under safe mode and use system restore point. Go to a point before that update happened, start from there.
Jun 30, 2012 | Microsoft Computers & Internet
Code 80070005
This error mostly appears due to windows update. If you are trying to update windows error then this microsoft link can help you:
http://answers.microsoft.com/en-us/windows/forum/windows_other-windows_update/cant-install-win-7-sp1-error-code-returned/c8c38825-e838-46c3-940e-417e0a7cb47a
Also use a system utility software like RegInOut to fix such kind of windows errors.
Dec 24, 2011 | Dell Inspiron 531s Desktop Computer
Updating windows Vista to Windows 7. Getting error code 80070005
Its better to do a clean re-install than upgrade. You will have more problems after upgrade. Just back up your data (external drive recommended) before you re-install.
Jun 18, 2011 | Microsoft Windows Vista Home Premium DVD...
Windows messenger will not conect error code 80070005
To fix this issue:
Go to Control Panel > User Accounts.
Manage Users Accounts > Advanced Tab
Manage Password.
Remove all of the passwords in the list.
Shut down MSN Massanger and start it back up.
You should be able to login now
Make sure your in an administrator account.
Jan 08, 2011 | Computers & Internet
Error 80070005 live messenger
this is registry error run reg in out registry cleaner
Sep 23, 2010 | Microsoft Windows Live Messanger
Computer always shuts down during downloads
This may be because your downloader software's setting has been configured to shutdown after download completes. Check settings
If this is not due to settings then your computer is infected. You need to reinstall your Windows OS.
If you have more question you can ask here
Jul 10, 2009 | Microsoft Windows Vista Home Premium...
Error code 80070005 when trying to install lcd flat monitor HPw2207H And also cannot get windows updates
Code Error 80070005 - Access Denied message. Permissions problems.
Please make sure that you are logged in as computer administrator. If you are not sure then go to User Accounts under Control Panel, Create a new user, set the user type to Computer administrator, logoff and log in to the user account you just created. Then try your procedure again.
Nov 24, 2008 | HP Computers & Internet
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
1.
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
Error code 80070005
http://www.computerperformance.co.uk/Logon/code/code_80070005.htm
follow the instructions from the link above and this should solve your problem
please rate this solution if it helped you
many thanks nick
Dec 10, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
