Question about Vehicle Parts & Accessories
Cool start remote FCC ID M65TX605 C534(roman num.2)TX
Remote is in a 2002 silverado 1500 and does not work.
  • 27 Answers
SOURCE: REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
Posted on Dec 18, 2008
SOURCE: COOL START REMOTE NEEDS REPROGRAMMING
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Posted on Dec 23, 2008
jpk528
  • 95 Answers
SOURCE: ezee start remote stopped working
if you have the manuals look under transmitter programming. if not go to crimestopper.com and look under manuals and you can download one from there and follow the steps into reprogramming the transmitter.
Posted on Feb 19, 2009
jpk528
  • 95 Answers
SOURCE: my aunt's car has an
go to crimestopper.com and go to manuals and click on the remote start that you have and you can download the manual and follow the transmitter programming.
  • 20 Answers
SOURCE: Cool Start model CS34-II TX manual
the problem with this remote is that it is used for a bunch of different models you have to look under the dash and get your unit model number and then check the crime stopper manuals for that units number you do this at www.crimestopper.com under support tab click on manuals and manuals again and then choose the model number you found under your dash
Posted on Feb 09, 2010
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
2006 silverado wt 1500, had a remote start system installed and power locks. Shortly after the truck wouldn't start at all anymore. So had the remote start disabled but the power locks still work. Since...
Aftermarket remote start systems are notorious for starting concerns due to the fact THEY ARE BYPASSING YOUR THEFT DETERENT FROM THE FACTORY.Definately in the remote start system.Are you using the factory remotes to open the doors?
Dec 02, 2010 | 2006 Chevrolet Silverado 1500 2WD
I have a 2002 Chevy Silverado 1500. I installed
There is a great write-up here: http://newrockies.ca . This was the only system that saved my Park Avenue.
Apr 28, 2010 | 2002 Chevrolet Silverado 1500
Oct 17, 2009 | 2-Way Remote Starter
Dec 16, 2008 | 2-Way Remote Starter
Vehicle Parts & Accessories Logo
77 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
