Question about Coleman 5232F-640T 110-Volt Power Supply For Thermoelectric Coolers
My cooler dose not get cold
Wont get colder than 40 degrees but i can hear motor running
Wine cooler too cold
The 2 @ 47 degrees may be low in refrigerant gas. Refrigerators are design to operate with an exact amount of gas. When the gas charge gets slightly low the system will operate colder for a time and when the gas charge loses a couple of ounces the system stops cooling. Another cause may be the thermostat isn't operating properly and or the temperature sensing bulb may be too close to a source of heat.
Feb 09, 2014 | Frigidaire 35 Bottle Wine Cooler
How to get bus ac colder
to me 60 degrees is cool .R134 not going to get but so cold.40 and 50s way too cool need wear jacket.only thing will get that cold is refrigerator gas wont work in automobiles.
Jul 05, 2013 | Cars & Trucks
98 explorer 4.0 SOHC wont idle and stalls when weather is below 40 degrees. worse when colder. Just had tune up, new airfilter new fuel filter but problem did not get better.
you have a bad idle air control valve. its job is to have motor rpm high until the motor warms up then turn it back to normal.
Jan 23, 2013 | 1998 Ford Explorer
Cylinder running cold
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
help please Cylinder 2 4 cold not firing
cold second cylinder exhaust carb issue XJRider com
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Aug 30, 2012 | 1985 Yamaha XJ 700 X Maxim
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
I have a True GDM 33 model is it possible tochange the temperatur
If your cooler is constantly running too cold the thermostat is probably bad. I can hook yu up with a thermostat. ;) www.northeastcooling.com
Nov 18, 2008 | True GDM-33-SSL-54 Refrigerator
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Coleman 5232F-640T 110-Volt Power Supply For Thermoelectric Coolers Logo
Top Coleman Electronics - Others Experts
Coss
Lawrence Oravetz
cwradio73
Are you a Coleman Electronics - Other Expert? Answer questions, earn points and help others
