Question about Home
What kw is a berry magicoal active 850 shower
2 Suggested Answers
  • 21 Answers
SOURCE: no hot water from electric shower Berry magicoal Action 850
you need to replace the element probably. you have a short which is a wire touching sometimes then it gets away
Posted on May 10, 2010
I have a triton Amber 3 shower. No water flows when switched on - but the mains LED is lit and water is available
the solenoid has failed,thus not opening up to allow water flow,i have found that spares are fairly expensive for tritan. if you find out the rating ie 7.5 kw etc then buy a replacement shower from wickes their showers are tritan and are normally like for like fitting,also a lot cheaper than showers that have tritan marked on them.
Sep 05, 2011 | Home
Hi, We have a old 5-port diverter valve (Grohe 29 605) in our shower in which the outlets are connected thus: Hand held shower port connected to hand held shower Fixed head shower port connected to body...
yep replace the unit the plumbing will be ok for a new unit, with a setup lie that whoever installed it hopefully was smart to put shut off valves behind the wall or you will have to turn off h20o supply and replace and solder caps on the rest easier to change out to new
Mar 04, 2017 | Plumbing
I have a galaxy obsession deluxe 9.5 kw shower which will run for a little while but then trips the fuse, what could be causing this to happen?
your cable supplying power is not correctly sized for the shower causeing it to overheat and trip the fuse, or your main board fuse isnt matched to the power of the shower
Dec 19, 2010 | Galaxy Vacuums
Triton Ivory 2, 8.5 kw electric shower flow has been getting porgressively weaker. Mains pressure if fine. Shower head is clean.
there could be a blockage on cold water connection which may have a filter which needs cleaning or the heating tank inside the shower could be blocked with limescale try cleaning the filter you cvould also check the shower hose for blockages or kinks
Dec 09, 2010 | Home
My triton shower blew its fuse a couple of times and came back on when I 'flipped the switch' back up. Now it's given up altogether. What's the problem?
Assuming that the circuit and fuse protection you have is correct for the kw rating of shower unit the most likely cause would be an element failure however in order to be more definate relevent electrical checks would be required within the shower unit.
The Triton Service Dept who may be contacted by telephone on 0844 980 0750 would be able to arrange a sevice visit for you where the problem may be investigated further for you.
Regards,
Karl
TRITON TECHNICAL TEAM
Oct 05, 2010 | Home
No hot water from electric shower Berry magicoal Action 850
May 10, 2010 | Home
Dripping showerhead mirasport 8.5 kw - shower is approx 15 yr old when switched to off continues to dribble then drip for hours after
It is normal for instantaneous electric showers to drip after shutting down. However, yours sounds as if the water stop valve is failing.
You could have this replaced ( or even cleaned out, sometimes they can be affected by calcium build-up on the seal) but realistically it's probably best to consider unit replacement....15 years is an excellent service span for an instantaneous electric shower.
Hope this helps.
Mar 03, 2010 | Home
I have a General ER - 34 JW(W) Fridge and I need to know the wattage of the fridge
Hi
This Fridge uses 668 KW/H/ Yr. as per Energyguide US gov. tests.
This come to 80 Watts per Hr.
Regards
Berry
Feb 01, 2010 | General Refrigerators
Home Logo
245 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
