Question about LG WM3875HWCA 4.17 cu ft front load steamwasher
I need to remove the front of and lg washer - LG WM3875HWCA 4.17 cu ft front load steamwasher
  • LG Master
  • 17,130 Answers
Click this link : removing front panel
Posted on Jan 12, 2013
I have an LG washer that will not unload water
Washer Won't Drain
1) Check your drain hose to make sure it's not kinked, plugged, or frozen
2) Check that the impeller for the drain pump isn't plugged. It's behind the service door at the bottom left front of the washer. If it's plugged remove the obstruction.
If these solutions don't help you may wish to get an authorized tech in. The other possible causes include a disconnected or damaged connector (the front of the washer must be removed to access its location), a defective Drain Pump Assembly, or a defective Main PWB (system Board) Assembly.
Additionally, diagnosing the last two causes involve significant dis-assembly, multimeter testing while the washer has power, and purchasing expensive parts ( Pump $60US, Board $190US).
Finally, if you live in Canada there's a problem getting replacement parts; LG Canada's policy is to only supply parts to service providers. Additionally, while LG US will sell individuals parts, you would have to get any parts you need shipped to someone in the US who can then forward the parts to your Canadian address.
Jun 29, 2014 | LG WM1814CW Front Load Washer
Need to remove pump on LG WM2701H washer
To get to the pump you need to remove the top plate, control panel and front cover in that order. for the front cover open the lid at the bottom left side and remove screws.
May 01, 2014 | LG WM-2277HW Front Load Washer
Door latch wont unlock LG WM2455 Front Load Washer
You can also gain access from the back by removing the back panel...The top on this washer can also be removed..Remove the dispenser cover...Take a putty knife..Insert it in between the top cover and the cabinet ..Push in the tabs located 4 inches in from the sides.
Oct 20, 2012 | LG WM2455 Front Load Washer
Does anyone know how to remove the top cover of the LG wm-2277 hw after the screws are removed from the back ? Have a water leak up toward the top of machine but cannot reach without removing the top ....
Disconnect the LG front load washer power cord from the wall outlet. Turn off the water supply to the washer at the water spigots coming from the wall.
Pull the washer 3 feet away from the wall, and disconnect the water supply hoses from the water inlet valve ports on the back of the washer. You may need a pair of channel lock pliers to loosen the hose connections.
Remove the screws securing the back of the top panel to the back of the washer with a Phillips-head screwdriver. Depending upon your model, you will have either two or four screws to remove.
Lift the back of the top panel up, and slide the top panel toward the rear wall, which will unhook the top panel from the clips securing the panel in the front of the washer. Lift the top panel off the washer and out of your working area.
Dec 27, 2017 | LG WM-2277HW Front Load Washer
Thermistor on wm2487h*m lg washer
usually on the front outer drum wall. front of machine will need to be removed.
Jul 02, 2010 | LG WM2487H Front Load Washer
LG front loader washer error LE how to fix
probably a defective motor hall sensor. will require dissassembly of motor via rear panel of machine. you will need a #17 socket and breaker bar to remove rotor nut. also, you will then need a #10 socket and driver to remove motor stator. sensor will be underneath attached to stator.
Jun 26, 2010 | LG WM1812C Front Load Washer
LG Front-Load Washer WM2277HW ce sign
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Jun 07, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer not working with ce showing
Sgt 48
LG WD12311RD FRONT LOADING WASHER DRYER.
Those bolts have to be removed prior to use or you will damage the machine.  The drying issue has to be addressed by a qualified LG technician.
Mar 21, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM3875HWCA 4.17 cu ft front load steamwasher Logo
22 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
