Question about ASUS P5S800-VM Motherboard
Can't install linux
When try to install linux i got the message that there is no disk drives but ido it same hard disk with another mother board i succeeded
  • 799 Answers
Probably should check in the BIOS and see if the HD is detected.
If not, you should check cables and connections (a bad cable will do it every time) power to the HD (can you feel/hear it start up?) Last resort to flash the BIOS. Try a different HD first and see if it is detected.
Posted on Jan 22, 2009
Will not start, operating system not found
You even can connect a floppy disk drive to this 15 year old mother board.
You will need to setup the system complete, with an old Windows or unix (linux) system. But you must be sure there is a harddrive connected and you should have the OS installer on a floppy disk.
If there is no Hard disk in the system at all, don't even try to install anything, because it won't work.
Be aware even when you manage to install something, most modern software and most hardware won't work with this system.
If it worked before, and it suddenly became like this, most likely the hard disk died. Will be difficult to find one that will work in this system. Try it on eBay.
Mar 15, 2015 | Computers & Internet
Using nexxtech 2.5
its just maybe that the device is not compatible with linux. try that to windows xp and see what happen.
CHARCOIS
Aug 27, 2008 | NexxTech Computers & Internet
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
I lost my mother board driver what will ido now
Hi Naresh,
Please remember to backup your drivers from the original driver CD onto your hard disk/Cd/Pen Drive , or specially a separate partition on your hard disk so that you can install them later, in case of any crash.
For now you can download the drivers from this link :- http://bit.ly/mUHx0w
Hope this helps.
May 12, 2011 | ASUS M2N-MX Motherboard
I've updated the BIOS but still can not get the mother board to consistantly recognize a new 1T Hard drive. It works once, but when I reboot it corrupts the Windows XP and the recovery partition.
Can you temporarily attach the "new" disk-drive as a "slave" disk-drive in some other computer?
Then, write some files onto the disk-drive, restart the computer, and see if the files are corrupted.
If they are, then the disk-drive is defective, and can easily be replaced, under warranty,
either from where you bought it, or directly from the manufacturer.
If the files are OK, then it's your motherboard that is the problem.
Dec 08, 2010 | ASUS P4SDX Motherboard
Mother board P4S800MXSE - message:
Your primary is your boot drive c) If you do a disk check it might be able to fix bad sectors unless there is physical damage.
Jan 29, 2010 | Computers & Internet
Trying to install server 2003, error message is setup did not find any hard disks installed in your computer, system has two drive w/xp (fdisked for clean install)
If you have SATA harddrives you must install the drivers before the OS. Usually the mother board disk contains these drivers or download then for the HD manufactors.
May 06, 2009 | Microsoft Windows Server Standard 2003 for...
I have two T-42 think pads with the same problem. They will not boot. Message says "cannot find operating system". I have the IBM recovery disks. When trying to run them get message saying...
It seems that the recovery disk u are using may be defective.Try to load os with another os cd.If every thing goes fine replace the recovery cd,otherwise it may be a defective motherboard.consult thinkpad service.
Jul 09, 2008 | Computers & Internet
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
ASUS P5S800-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
