Question about Back to Basics -- Plastic Bucket Ice Cream Maker - 4qt -- Model IC1088
Is the paddle supposed to spin
My silver bucket is spinning but not the paddle inside, is it supposed too? If so what's wrong?
    New Friend:
  • 3 Answers
Your paddle won't turn. Your silver bucket is the one moving (turning) and not the paddle. It's working like it should. I thought the same before I found the lid (cover).
Posted on Jan 17, 2013
My bucket and spendel has been broken , i want spare one
sadly we are not the manufacturer of this item , check with them
Dec 27, 2015 | Nemox Gelato Pro 2500 2.5 Quart Ice Cream...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
NOT FREEZING PROPERLY
If your outer bucket is leaking down the liquid brine solution it won't freeze properly. The rival buckets are bad about leaking. You might try pre-conditioning the outer bucket before making your attempt at freezing. Just fill the bucket to the weep hole with water and let it sit for about half an hour, then pour out all but about 4 inches of it and start adding ice and salt.
Jul 04, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
Metal shavings in ice cream
Sounds like the center rest in the bucket might be worn or gone and letting the cannister ride too low in the bucket.
May 09, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
Is the paddle supposed to turn all the time?
This just popped up on my screen. Are we talking about a ide cream maker? IF yes ... generally, the can revolves around the paddle. The paddle doesn't move.
Hope this helps.
Sep 06, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Paddle not rotating
The paddle is supposed to scrape the frozen mix off the inside of the can as it turns. So yes, that sounds right.
Oct 18, 2007 | Rival 8420-TB 4 Quart Ice Cream Maker
Back to Basics -- Plastic Bucket Ice Cream Maker - 4qt -- Model IC1088 Logo
215 people viewed this question
Top Back to Basics Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a Back to Basics Ice Cream Maker Expert? Answer questions, earn points and help others
