I would try the web site driverguide.com and fill out a free
registration search the data base for your driver download and install
the reboot your computer
Do the on-board LAN works properly. If not, install the motherboard drivers. A CD should be there with this Gigabyte MB, has to be installed to get all the Chips Drivers.
If you're trying to get drivers for a separate LAN adapter, other than the on-board one, just make the on-board LAN to get work, connect your BB connection to it, and the system will search for drivers for it by internet. Follow the instructions you see there. Gopakumar Gopalan Google
I assume the LAN adapter driver is installed and is working properly. The LAN cable maybe faulty. If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router. Try a another LAN cable..
If it is not onboard LAN card reinsert it after cleaning it's concact point with pencile eraser. And user proper driver for it. I think you don't have proper driver for your LAN card.
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
Hi, Here is the web page for your vga, lan and audio drivers: http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=+HP+dx6100+mt&submit.x=6&submit.y=6
Hi there. Those drivers aren't the right ones.
Did you go to the laptop brand website and download the correct drivers? Sometimes they have different types of drivers depending on what type of LAN adapter there is on the computer.
Sometimes there are drivers for Broadcom LAN adapters or Intel. If it doesn't work with one, try the other one.
good luck
make sure that the local area connection in the computer is enabled and that the drivers of the ethernet adapter are working properly.
try to reset the router by pressing the reset button for 30 seconds then if the problem still persist then that means the router should be replaced already.
If you are unable to resolve the problem with your intergrated lancard then you can add additional LAN CARD on your computer or you can also buy USB to LAN CARD adapter.
