Replace pump how do i replace pump. how do i access part from the front?
  • 691 Answers
On most washing machines there nothing major accessible from the front, you need to clarfy what model and make?
Posted on Jan 11, 2013
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
I have a Frigidaire Front Loader Washer Model # ATFB6000FSO which at times does not drain or makes a loud noise during draining. I believe I have a clogged water pump or filter. What is the best way to...
You need to lean it back and remove the lower panel, you will have complete access to the water pump, disconnect hose clamps,remove and clean the rubber boot,disconnect electrical connector and 2 screws holding pump, Replace with new pump, before beginning take pictures to ensure proper installation
Nov 19, 2017 | Frigidaire Affinity ATF7000E Front Load...
MACHINE NOT SPINNING OR DRAINING
You most likely have a clogged or faulty drain pump. To access this: 1. Remove the bottom access panel. 2. Remove the front of the pump filter. Keep in mind that when you do this all the water in the machine is going to come out. 3. If the filter of the pump isn't clogged then you likely need to replace the pump assembly.
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The water wont drain and the is a clicking noise coming out of the water pump motor
Something may be stuck in the pump impeller causing it to make a clicking or rattling noise. Disconnect power then remove the lower front access panel to access the pump filter and the pump impeller.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Drain the water into a bucket or shallow pan and lay a piece of towel under the pump filter prior to the removal of the filter. Turn the filter knob counterclockwise to remove and clean it. Reach in the pump to check if it is restricted or detached from the pump motor spline. Replace the pump assembly if the impeller is broken or detached.
Oct 04, 2010 | Kenmore Elite 45986 Front Load Washer
Do you have to remove the fuel tank to replace the fuel pump ?
No. The fuel pump can be accessed by lifting the read seat. Press on the front edge of the read seat to lift it up and this will expose an access door. Remove the bolts on the access dooor and the fuel pump is visible. Disconnect wiring harness and run engine to depressurize feul system. Now remove bolts on fuel pump to replace with a new one.
Aug 25, 2010 | 1990 Toyota Tercel
We need to replace the drain hose in our Kenmore Elite HE3t washing machine. How do I get access into the machine to replace the hose? Is it from the top or the back?
To replace the drain hose, follow these steps:
1. UNPLUG the washer and turn it around so you can access the rear panel.
2. Use a wet/dry shop vac and pull a vacuum on the drain hose. This will remove any existing residual water that remains in the drain line and pump minimizing any mess you may have to clean up later. NOTE: There is about a gallon of residual water that normally remains between the lower wash basket, drain lines and pump.
3. Remove the rear panel by loosening the screws around the perimeter of the back panel. With the screws removed,the panel should lift off. NOTE: There is a smaller access in the center of the back panel that can also be removed. Removing the entire back allows for better access though. Trying to work through the center access can be a cut hazard due to the sharp edges on the metal.
4. Move around the the front of the washer and remove the lower toe panel under the door. You may have to prop up the two front feet of the washer to access the screws under the bottom front edge. With the screws removed, the panel will drop down, then lift off.
Additionally removing the front toe panel will give you full access to the drain pump from the FRONT and the REAR. The pump sits closer to the front of the washer where you can easily access the hose clamps. The drain hose inserts from the rear, however.
Since you have the washer apart, now would be a good time to check the drain pump clean out trap to ensure there is no debris build up that can restrict drainage. The following link explains the recommended procedures to check the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you have any questions about any of this advice, please post back and let me know. I hope you find this information helpful.
Feb 08, 2010 | Washing Machines
Washer will not drain.
access the pump clean out at btm front panel .should be small hose to drain with bucket,remove cap and youll probably find coins /debris that is stopping the pump from draining.The pumps do go bad though...make sure the impellers are not broken.To replace, 3screw 2 hoses and 1 plug,can access from underneath unit.Please rate my answer :)
Dec 08, 2009 | LG WM0642H Front Load
We washed a small rug and we got an E-20 code. what should we do, its having problems draining!
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Jul 12, 2009 | Frigidaire GLTF2940ES Front Load Washer
How easy to access the 3 screws?
Underneath. Don't see original post here, but to replace a pump (actually, just the pump motor) on an LG front load washer: Drain water out of small hose inside recess and remove access door cover (at lower left of machine). Remove one phillips head screw and use a plastic putty knife or similar tool to push in on left or right side of recess to remove the plastic recess cup. Now remove the two other phillips head screws visible. Tilt machine back and access pump Assembly from under machine. There is a tab that you will have to work loose. Disconnect electrical wires from pump at disconnect plug. You probably want to remove the hoses going to and away from the pump (squeeze clamps). Pump motor is easy to change out now with three more phillips head screws.
Sep 02, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
