Question about HP Officejet 6310 All-In-One InkJet Printer
Hp photosmart 5514 one or more cartridges appear to be missing or damaged
I get an error one or more cartridges appear to be missing or damaged. I have replaced my cartridges 3 times with not help. I cleaned the contacts, check the vents on top and cleaned the contacts on the printer. Don't know what else to do
    New Friend:
    Problem Solver:
  • 15 Answers
You could try replacing your printer head
Posted on Jan 11, 2013
professor_sc
  • 180 Answers
SOURCE: ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Posted on Mar 07, 2009
ctf1800
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035736&cc=us&lc=en&dlc=en&product=305375&dlc=en&lang=en
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
SOURCE: remove an check cartridge problem in HP 2410xi printer
bought new
Posted on Apr 09, 2009
Comp-U-Doc
  • 148 Answers
SOURCE: Blinking lights plus E sign for cartridge error -
Look carefully to make sure there is no paper jammed inside. Sometimes there can be a small piece of paper that tore-off in the gears causing a paper jam.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 11, 2010
I am still not able to resolve the error message below after trying suggested solutions. I might add that my printer is not used frequently. Could it be damaged beyond repair because of this? Getting...
Hi, do note that even if you are printing in black, the printer requires that you have installed functioning cyan (blueish), magenta (reddish) and yellow cartridges as well.
Feb 10, 2015 | HP PHOTOSMART PLUS B209A All-In-One...
NVM reset for hp photosmart c4780
You can gain access to the service menu...refer to Cartridge Error Clear bypass procedure below (as guidance of how to get in):
For any severe cartridge error related message, on the HP C4600, C4700 or D110a printer models, I suggest you run the internal Tap 41 diagnostics test which will tell you the electrical health of the ink cartridge - in many cases the cartridge is internally electrically damaged and will need to be replaced. In addition, you can temporarily bypass an 'incompatible cartridge(s) or Missing/Not Detected error message by performing the Cartridge Error Bypass procedure...refer to two Youtube videos on how to do this:
HP Photosmart C4600 & C4700 Printers - Tap 41 Diagnostic Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
Low Ink Warning and Other (i.e Incompatible Cartridge) Errors, HP 60 & HP 61 Ink Cartridges:
http://www.youtube.com/watch?v=5_suW3U6e08
Feb 28, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Cyan color cartridge "appear to
http://h10032.www1.hp.com/ctg/Manual/c00485555.pdf
Apr 22, 2011 | HP Photosmart 3210 All-In-One InkJet...
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP Officejet 6310 All-In-One InkJet Printer Logo
546 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
