Question about Tag Heuer WAF2110.BA0806 Aquaracer Automatic watch
Tag automatic watch = stopped working
Hi, my tag automatic link watch stopped working. if i shake it a bit it starts working until i stop shacking it and then it stops. please help. what should i do
  • Anonymous Feb 15, 2009
    I'm having the same problem with my Fossil ME1025.
  • Anonymous Apr 22, 2009
    same problem i have a copy rolex automnatic it stopped but when i shake it it works for like a minute and 2 then stops dont knoo wats wrong??
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Posted on Apr 17, 2009
  • virgilio1440
    virgilio1440 Apr 21, 2013
    Ha...Wrong! If you look closely at the back of your Carrera, you'll notice a mechanism that spins. This is your auto winder. If this isn't spinning, your watch isn't auto winding. I've had an intermittent problem with my Carrera since I purchased the watch. It's aggravating and I don't know what causes it to stop working, then start working again. If there's any insight to this, please give a reasonable answer.
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
My tag heuer link automatic stopped working what could be wrong with it
Assuming the watch wont start when worn then its time to get a specialist watchmaker to investigate.A premier watch as you have will need regular servicing at 3-5 year intervals.try www.rolexrepairs.co.uk they will provide a free estimate and operate a fully insured postal service.
Aug 16, 2010 | Tag Heuer Link Automatic Chronometer...
Tag Heuer 2000 Automatic not moving
Sounds like your watch is in need of service. All watches need to be maintained and regular service is required. A watch is a tiny machine. So if you think about it a car needs regular maintenance to keep it running and so will any machine.
In a watch the oils dry out after about 3-5 years and they stop lubricating. Just like in a car when the oils stop lubricating the engine will stop, a watch will stop.
The reasons for this are 1) no lubrication means high friction on the moving parts. 2) the dried oils become gummy like glue and hold the gear train in place which keep the gears from moving.
The only answer is to have your watch serviced to get rid of the old lubrication, clean and replace any worn parts, then reassemble and lubricate, and finally adjust the timing.
This is something only a watchmaker should do as the parts in your watch are very small and very fragile. Improper handling can permanently damage the parts.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 24, 2010 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Hi.i just boughta tag heuer grand carrera xx007344.immediately i got home,it stopped working.so,after abit of winding it starta working.but if i just drop for a minute or two,it stops working.even when...
Automatic watches will generally run for 2-3 days before the spring is fully unwound, so you are likely to have bought the watch in the unwound condition.
It can be wound by gently shaking the watch from side to side (for about 100-200 times). This should give it sufficent engergy to operate and thereafter normal use will keep it wound up.
If it stops working when the watch is rotated out of the face up position, then it may be that the watch is faulty. (If the watch has been dropped in transit, it may have been damaged).
If normal operation is not achieved, then send it back to get it repaired under warranty.
May 04, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
Hi my tag heuer monaco has stopped working but when i wind it to the correct time it starts again for a while, what is wrong with it
I'm sure its an automatic - next time it stops do not set time just shake it and see it if starts again - automatics need to be worn most of the day to last during the night
Mar 04, 2010 | Tag Heuer Watches
New Tag Aquareacer Automatic wont manualy wind
If thats a new watch then there could be an issue in the movement and its possible it could be covered under warranty. Take it back to the store asap!
Jan 15, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Jan 10, 2009 | Rado Diastar Anatom Jubile watch
Tag heuer link automatic
exact same problem, no one seems to know
Oct 26, 2008 | Tag Heuer Link Automatic Chronometer...
Tag Heuer WAF2110.BA0806 Aquaracer Automatic watch Logo
6,698 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
