Question about Samsung SMH9151 Microwave Oven
I have a sumsung SMH9151s microwave that recently started having problems. Now it keeps beeping and in the display its going back and forth to the letter L and back to 0. I tried unplugging it and plugging it back up but nothing seems to help or fix it and nothing else works. It keeps going back to the beeping and the weird display and its not displaying E codes or anything like that so idk
  • Samsung Master
  • 17,130 Answers
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Posted on Jan 12, 2013
5 Suggested Answers
SOURCE: Samsung Over range Microwave
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
Posted on Apr 17, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
Posted on Apr 10, 2007
  • 8909 Answers
SOURCE: samsung microwave model MW6573G
That sounds like the control panel or touch button pad is faulty.
Did it get wet from condensation at all?
Hope that helps
Posted on Feb 26, 2011
billinghurst
SOURCE: The microwave display shows "--SE--" I have not
This fixed mine.
The problem lies with the mylar ribbon cable that connects the Keypad to the circuit board. The Mylar ribbon cable folds back onto itself and are touching. Over time the mylar 'breaks down' electrically and the wire traces in the mylar will 'arc' onto the other mylar ribbon cable. The solution is to separate the two mylar ribbon cables using paper and electrical tape. I've done this on several microwaves (not just Samsung) and it has worked every time. Patience and about 20 minutes is all it should take to fix it. I've described below how I did it for the SMH9187ST Microwave Good luck to all.
1. UNPLUG THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2) screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch (there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad Housing (phillips). Lift the Keypad Housing upwards about half an inch (there are tabs holding the Keypad Housing in place) and remove. Be careful of the metal grille that is just above the Keypad Housing as this may fall out since it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses that are attached to the Housing. Carefully unplug the wiring harness that has the RED connector on it from the circuit board. Carefully unplug the small white connector that has the mylar ribbon cable on it (this cable is see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit board onto the Housing.
7. The Housing should now be free of the circuit board and wiring harnesses. It's safe to let the wiring harness/circuit board hang free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing. There are (4) plastic tabs holding the frame in place. Using a small screw driver pry one side of the frame away from the housing (try to do this to the side that has smaller plastic tabs). When this side of the frame is free of the Housing you have to lift the frame out at an angle to remove. It might put up a fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the mylar ribbon cable that is coming out from underneath the Keypad assembly. You will notice that the mylar ribbon cable folds back onto itself as it re-enters the Keypad assembly. This 'touching of the two ribbon cables' is where the trouble lies. The ribbon cables may be stuck together. Carefully separate these two and then insert a small piece of paper between them (paper can be 1/2 x 1/2 ) and work the paper all the way down into the Keypad assembly as far as it will go.
10. 8. Using electrical tape, apply a small piece between the ribbon cables to hold the paper in place. Next, use more electrical tape and put it between the mylar ribbon cables enough so as to keep the ribbon cables separated.
11. 9. Re-attached the thin metal frame making sure to press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw metal edge of the thin metal frame to prevent the mylar ribbon cables from rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful when inserting the ribbon cable connector back on to the circuit board. The connector is loose and you need to gently place the ribbon cable into the circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset and ask you to set the time.
16. Hope this works for you !!
Posted on Oct 24, 2012
Samsung microwave oven Model # SMH9151S. Turntable not turning fan inside (not the exhaust fan) is not working either.
It may be a failed relay on the control board, which I repair affordably.
See my profile picture if you need more help.
Jun 22, 2015 | Samsung Microwave Ovens
How to change a membrane switch on a samsung microwave model number smh9151s
This is actually a simple DIY job. The service manual is at my site here.
You simply move your circuit board into a new control panel frame assembly, which comes with a new keypad already attached.
For model SMH9151S, it is part number DE94-01806K ("Assy Control PANEL") and you can order it from the Pros here for about $42.
If it is not in stock when you order, they can have it to you in just a few days.
You can also find helpful exploded view diagrams and order other parts via that link.
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes. If you have trouble, slide the hood vent grille to the left about 1/4", then then pull it forward. Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame. Be careful, since the display is made of glass.
fetch.cgi?redirect=http%3a%2f%2f031d26d.namesecurehost.com%2fmwd%2fkeypad_connector.jpg
Some connectors on the relays have a lock:
Jan 04, 2014 | Microwave Ovens
Need to install membrane switch model number smh9151s
Jan 04, 2014 | Samsung SMH9151 Microwave Oven
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
The display panel readout has a 5E or possibly a SE on the dislplay constantly
SE error means you have a shorted membrane keypad.
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
We would need the model number in order to provide you with free assistance.
It will be one of these:
SMH9151B
SMH9151B/XAA
SMH9151B/XAC
SMH9151BE
SMH9151BE/XAA
SMH9151S
SMH9151S/XAA
SMH9151ST
SMH9151ST/XAA
SMH9151ST/XAC
SMH9151STE
SMH9151STE/XAA
SMH9151W
SMH9151W/XAA
SMH9151W/XAC
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions, or you may contact us here for this free assistance.
In some cases, it is a simple do it yourself repair.
Sep 18, 2011 | Samsung SMH9151 Microwave Oven
I don't know why my microwaves keep beeping and starts the Exhaust Fan automatically every 5 mins. The display says F-3. Please help me with the problem I'll appreciate.
F-3 is usually for the temperature sensor being faulty. What you need most likely is to replace the temperature sensor. This would explain why your microwave oven exhaust fan keeps going off, because your temperature sensor is telling it that it is overheating even though it isn't.
Jul 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Satanic microwave
Dude, that totally happened to my boyfriend and me! He woke up in the middle of the night to the beeping and went downstairs to check it out. It was like 3am and the microwave started displaying all 6's. Then a helicopter flew right over our apartment and he started really flipping out. Talk about scary.
May 01, 2008 | Microwave Ovens
Microwave keeps beeping
how do you re-set microwave oven
P70D20AL-D4 is the
Apr 15, 2008 | Microwave Ovens
Samsung SMH9151 Microwave Oven Logo
262 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
