Question about Sewing Machines
TENSION SETTING FOR DENIM PRO FINISH 14CG754 - Sewing Machines
4 Suggested Answers
forgot
  • 17 Answers
SOURCE: baby lock denim pro
try putting some bee's wax around your spool
Posted on Dec 09, 2007
SOURCE: have singer 2 needle serger diagram to small to read it
problem solved inlaged diagram,thks ****
Posted on Jan 14, 2010
  • 980 Answers
SOURCE: what is the denim tension setting on the singer
Just adjust the tension so you ger a perfect stitch top and bottom
Posted on Aug 08, 2011
Tension setting for sewing denim on brother LS 2125
Refer to 'Manuals Online', Brother sewing machine user manual. There is an excellent guide to tension settings for all fabric types. Also remember to check upper and lower thread has been wound through correctly and are using the same thread top and bottom. Ensure you have the correct needle size for denim ie 100/16 and the correct thread size ie 40-50 cotton or heavy duty polyester.
Nov 09, 2016 | Brother Sewing Machines
Tension adjustment for denim with denim thread
If it is bunching and looping underneath, it's because either the machine isn't threaded correct on top or your top tension is too loose. For heavier sewing, your top tension should be set at 7 or 8.
Jan 12, 2015 | Sewing Machines
What is the ideal tension setting?
Ideal, is when the top and bottom thread don't pull the other the whole way through. If you go from thin cotton to denim, you will have to readjust the tension.
Dec 19, 2012 | Sewing Machines
Need tension wire
try sewingpartsonline.com
or
sewvacdoctor.com
a1sewingmachines.com
& email them about the part you need
Aug 10, 2012 | Euro-Pro Denim Sewlution 380 Mechanical...
What is the denim tension setting on the singer esteem 2?
Aug 07, 2011 | Singer Sewing Machines
Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I...
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
May 18, 2011 | Euro-Pro Shark 80 - 7133
Threading the denim and silk machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Jul 05, 2008 | Euro-Pro Deluxe 7100 Mechanical Sewing...
Deluxe denim euro pro
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
May 18, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Baby lock denim pro
Dec 09, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
