Question about iHome IH-U502FP Pink 4-Port USB 2.0 Hub
What is the power voltage for the iHome 4-Port USB 2.0 Hub IH-U502FP
Connect mouse
IH-M822WR Mouse is a plug and play mouse, you need to remove a small usb device from the stowage slot. This is the receiver, plug it into any USB port on the computer you are connecting the mouse to and then wait anywhere up to 30 seconds for it to connect the first time. If this doesn't work change out the batteries to ensure they are working. If it still isn't working try another USB slot that is not attached to the first one used. If this fails to work you may have a faulty mouse.
Oct 01, 2014 | iHome IH-M822WR Mouse, Red
Ihome IH-M826WC driver
The Microsoft mouse driver usually works with all pointing devices. It also has an extensive library of devices. Try different ones until you find the one that works.
Apr 16, 2014 | iHome IH-M826WC Black 5 Buttons 1 x Wheel...
I have mixed up my power supply for the IH-U582FB with other power supplies. What is the output voltage and is the center pin positive or negative?
Usually on the back of the unit next to the power plug-in there is a small symbol that looks like this -(o+ the circle represents the center pole if the plus sign is beside it then the center pole is positive sometimes the voltage is listed there also if not then look on the label on the bottom and the voltage and amp rating will be found there
Oct 31, 2011 | iHome 4port Netbook Hub Black IHU582FB...
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
iHome IH-U502FP Pink 4-Port USB 2.0 Hub Logo
56 people viewed this question
Top iHome Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
indiana650
indiana650
Level 1 Expert
Tom Chichester
Are you an iHome Computer and Internet Expert? Answer questions, earn points and help others
