Question about Bradford White MS80R6SS 80 Gallon - Solar Saver Electric Backup Residential Water Heater
Burnt out element - Bradford White MS80R6SS 80 Gallon - Solar Saver Electric Backup Residential Water Heater
  • 51 Answers
Are you sure its burnt out? Most of the time its the thermostat. If its burnt out then just change the element. To do that all ya do is shut off the power to the heater drain the tank unhook the two wires on the element and unscrew the element and replace it with a new one. You can get new ones at lowes or home depot. Its usually the bottom that goes out first.
Posted on Jan 12, 2013
Replace hot water heater element?
buy a heater continuity tester. $9.00 at home depot. Turn off breaker to hot water heater. test both elements, though i'd start with the top one first it's usually the one that goes bad. drain water before removing element that's burnt out. I open the pressure relief valve to speed that up. replace with like element same volts and watts is important.
Feb 22, 2015 | Water Water Heaters
Hot water heater will not turn on
You need to have the unit checked. Two possibilities come to mind if it is an electric water heater. 1. Burnt out heating element. 2. Failed thermostatic element switch located in the unit. Many water heaters have two elements.
Jan 15, 2015 | Water Water Heaters
Just today the water isnt hot. Yet the boiler is working.
Is the water warm at all? How are you able to tell that the boiler is working? If this water heater has an upper and a lower element then one or both may be burnt out. If only one is burnt out then you will usually have warm water but not HOT water.
Nov 07, 2014 | Water Heaters
My electric boiler (80litres) is only giving out about half the capacity of hot water, then goes cold. On the temp; gauge on top the needle only reads half of what it used to.
The unit probably has two heating elements and the bottom one is burnt out, therefore only the top portion of the tank is heating...
check and change the bottom heating element.
heatman101
Apr 23, 2011 | Water Heaters
The titan water heater does not heat. The unit shows that it is on.
Most likely it is because the heating element is burnt out inside the heater....
You will need to replace the heating element or replace the heater...
heatman101
Feb 01, 2011 | TitanNet TITANTANKLESS. COM PRESENTS THE...
When i plug in the insink erator and turn it on it blows the breaker is it the heating element or the switch or the thermostat
The first thing I would check would be the switch. then the thermostat then the element.I would also check for any burnt insulation which could allow a short to ground.
My gut feeling would be the element but I like to eliminate the less expensive items first. Hope this helps. Thank you and have a good holidays.
Dec 22, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
How does the reset work? I am helping a friend troubleshoot his water heater. One of the wires that connected the pig tail to the power block fried inside the water heater cover. I decided to remove the...
The reset button is set up to open the circuit if excess current is drawn by a failed Element. It works by getting hot and switching off due to current above its rating. The burnt wiring more llikely happened over a period of time because of a resistive joint in the block getting hot due to the high current that water heaters consume. It seems that the element has failed if the reset button does not get the system working.
Sep 17, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
Rheem Electric 40 gallon water heater not providing heat
The elements may be burnt out you can check them by an electrical light tester. There is a lower and an upper element. If the tester lights up element is good. I hope this helps, please rate if the answer was helpful. Have a great day. Jeff
Apr 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water is hot but doesn't last long.
Your upper element is burnt out. open top cover, turn power of at breaker panel,drain hot water tank . remove black and red lead wires from the element use a socket to un thread the 3000watt 240 volt screw in element. re install the new element atach wires to element. Fill tank with water before turning on power or you will be replacing both elements very shortly
Feb 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Circuit breaker trips on electric hot water heater circuit
Check the voltage at the water heater. Sounds like the element is burnt out and is tripping the breaker.
If it is more then 5 years old I would check.install a new heating element.
Mar 27, 2009 | RELIANCE ELECTRIC WATER HEATER
Bradford White MS80R6SS 80 Gallon - Solar Saver Electric Backup Residential Water Heater Logo
66 people viewed this question
Top Bradford White Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
