Try removing the kick plate front bottom of your dw and see if there is a code chart paper stuck on the back of kick plate.. hopefully there is one.. good luck...
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
According to people who have had this problem before (error code E5 means blockage in the drain circuit) have solved it by
1:Remove the metal front panel from the dishwasher. this may be hidden by you kitchen kickboard its held on with 5 posi screws. 2: find a round black plasitc lump, similair to a yoyo!. 3:remove the rubber pipe that goes into it and blow down the pipe(you will hear air blowing into the dishwasher) then blow into the plasitc lump(you should hear it rattle) 4:put it all back together.
The black plastic lump is the pressure sensor, water gets stuck in it so the dishwasher thinks theres water inside so tries to pump it out but the pressure sensor still says there is water in so you get the error. Blowing through clears the water.
It is also a good idea to use dishwasher cleaner kit now and then- this is available from the super market in the dishwasher detergent section and is used with an empty dishwasher. Will get rid of all the muck that collects in the hoses and the drain.
Hi
I just had the same problem - which is how I came across your question. The spring in the mechanism had snapped and so it would not lock shut.
I have ordered a part from Belling online. I have already taken it apart and it seems straightforward.
One thing I would recommend - remove the outer facing panel first as it is very heavy. You will then find you only need to remove the top black section - make sure you turn the electricity off first and watch out for residual electricity in the control panel.
The part cost £16 with delivery. Should arrive in the next couple of days.
Adam
I just cleaned out the filter and took the drain pipe off the machine and flushed it out,looks like there was a partial blockage,machine has worked fine since.
Got this problem resolved pressed the first button and last button on the control and restarted the machine, seem to have cleared the problem...
Give it a go
thanks very much i will see :))
