Question about Altec Lansing ATP 3W Computer Speakers
Help i have recently purchased atp3 & my problem is thati can't control bass through knob on speaker. however i had tested it on my seller's computer & it worked just fine. is it due to motherboard. mine is XFX nforce 680i LT SLI. it has 8.1 highh definition onboard
  • 54 Answers
Maybe you should check the configuration of your built-in sound card.
Posted on Jul 05, 2007
SOURCE:
Altec lansing 221 computer speakers sound solution
Unfortunately it looks like Altec Lansing goofed up on this set and didn't provide a bass control knob. You will need to use some sort of software equalizer on your computer to turn the bass down.
Mar 24, 2012 | Altec Lansing 221 Computer Speakers
On a speaker on the computer what does the things mean? those nobs
Depending on the speaker versions, it can have a couple or several knobs. One to the left usually controls turning on the speakers and also controls the volume. The other knobs usually control the Bass and Treble sounds coming from the speakers. If you get more specific and give the actual brand, model I could tell you exactly what each is for.
Hope this helps.
Dec 23, 2010 | HP Compaq Computer Speakers
Bass sound coming out whenever i move the right speaker
seems like one of the wires is loose either inside the speaker or in the cable leading to it.
best chance is to open up the right speaker ( involvs damage to the plastic , since atp3 speakers are glued and practically unopenable with out breaking)
and then trying to play with the wires `till you find the sourse of the problem.
as soon as you know where the probles is , i`m sure its gonna be easy to fix, again , the hard part is to take this speaker apart.
good luck
Sep 08, 2009 | Altec Lansing ATP 3W Computer Speakers
Subwoofer not working
Yea I would say most likely a loose wire going to the bass control, is it accessable to behind the controller easily? if so take a look. they are usually soldered, but it may have been a weak solder point that came loose.
Jul 16, 2009 | Logitech X-230 Computer Speakers
Logitech S500 Volume Knob Broken
The simplest thing to try is some compressed air directed to the knob. This would clear out any dust or dirt that may be obstructing the knob. I am not sure what you mean by power cut so I am shooting in the dark here. If you mean a power surge that caused the volume to quit working then I would suggest an external volume control such as http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=pd_bbs_2/002-2257004-6895258?ie=UTF8&s=electronics&qid=1194009359&sr=8-2
Or
http://www.radioshack.com/product/index.jsp?productId=2102975&cp=&sr=1&origkw=volume+control&kw=volume+control&parentPage=search
Dec 18, 2008 | Logitech X-540 Computer Speakers
How to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
Speaker problem
check for the connections! unplug and plug then back! test it! if it still have the same problem then it might be at the circuitry already! maybe some electronic components were busted or malfunctioned already!
if you happen to open it! check for bulged capacitors or loose connected components on the circuity!
Nov 15, 2007 | Altec Lansing ATP 3W Computer Speakers
WOOFER SOUNDING BAD ON CERTAIN BASS FREQUENCIES
Try a software solution- download an audie editor like Audacity. The fault sound like a malfunction in the speaker unit ,which is not servicable.
May 17, 2007 | Altec Lansing ATP 3W Computer Speakers
Speaker/sub bass
Hi, it is possible that the sub volume control is worn out. If your particular brand/model uses the rotary/wiper type (variable resistor) then replacing it should do the trick but this involves soldering which be done by an electronics technician or qualified to perform such repairs/replacement. Hope this helps. Cheers.
Feb 20, 2007 | Boston Acoustics BA745 Computer Speakers
Bass destortion
yes u nee dto get the kilspe 2.1 promeadia speakers way better big bass rocks seprate bass control used set on ebay for 65
Feb 02, 2007 | Logitech R-20 Computer Speakers
Altec Lansing ATP 3W Computer Speakers Logo
99 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
