Question about Samsung V25 2600XPP (NV25NP0SJM/SUK) PC Notebook
Hi, my Samsung laptop v25 does not hold battery charge. I have replaced the battery with new one but it still does not hold it. thanks for help.
  • Samsung Master
  • 7,627 Answers
Is it charging? Does it Fully Charge? When you say "not holding a charge", how long are we talking about? Minutes, Hours? Battery life depends on what your doing and what is running and other factors, Some aftermarket batteries aren't very good. Inexpensive batteries are cheap for a reason.
Posted on Jan 12, 2013
SOURCE: Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Posted on Oct 11, 2008
SOURCE: blank screen
Might be the VGA connector to the motherboard.
Turn upside-down. Remove screw in the centre marked KBD.
There are 4 screws running along the back. Remove the 2 inner ones.
Lever up the keypad with a small screwdriver - Careful not to disconnect the ribbon underneath.
Undo the 3 screws along the strip above the keyboard and remove the strip.
VGA connector is next to the power button. Check it is pushed down firmly.
NKYG
Posted on Mar 03, 2009
belloso2
  • 71 Answers
SOURCE: Laptop screen too dark when used with battery
Are you using vista or xp?..The laptops to conserve power will dim the screen , you can , however, change it to brighter by pressing the "fn" key which stands for "functions"key. while pressing that, you should have another set of keys either to your right or obove your left finfers with the symbol fo a sun with arrows pointing up and down..press the fn and tap the up arrow key to increase the brightness.
Let me know if that works
Posted on Apr 10, 2009
SOURCE: hi my girlfreinds samsung v25
am selling samsung v25 would like to clear all my pics, music etc. and but back to factory settings
Posted on Apr 11, 2009
  • 406 Answers
SOURCE: Hi my Samsung V25 laptop cd/dvd not working how
You may get the new drive from Authorised service center or U may use external dvd drive which are available from retailers. Because the parts are not so easy to fix.
Posted on Aug 09, 2009
Basically my samsung n145 netbook wont power up unless its connected to the power supply and also i cant disconnect the power supply when fully charged as it cuts the laptop off straight away :( cheers
Replace your battery to solve this trouble.
Get a battery from a FixYa.com advertiser or anywhere computer batteries are sold.
Thanks for your question @ FixYa.com
Jul 28, 2011 | Samsung N145-JP01US Netbook
How can i turn on the wireless on samsung v25
well your laptop should stay on when you take it off of your charger if its charged. Usually when someone has the problem it means the battery on their laptop is no good. This usually happens when you let your laptop die and lose all its power from the battery this can really damage your battery. Thats the only thing I can think that happened. Your probably going to need to get a new battery. I hope I helped you.
Dec 15, 2009 | Dell Latitude E5500 Laptop
Hi i have a samsung v25 laptop does it come with wireless and if so how do i activate it please i will be very great full thanking you
there is a button to activate it or go to control panel then network connections and then enable wireless lan
Dec 01, 2009 | Samsung V25 CXTD 2000 Notebook
Samsung p28 not srarting up
If the battery is old, it will not charge enough to power up the unit. Take it to a computer shop and have them test it for you.
Sep 04, 2009 | Samsung V25 XVC 2800 Notebook
Hi my Samsung V25 laptop cd/dvd not working how can i fix it. Not very good at his sort of thing please help!!!!
Aug 09, 2009 | Samsung V25 XVC 2800 Notebook
Toggle keys for laptop to display through s video cable
Hi there.
Try this >>>>>>
Hold down the Fn key and press the F key which should have a wireless/radio antenna icon on it.
Post back if this does not work
good luck and thanks for using FixYa!!
Mar 24, 2009 | Samsung V25 XVC 2800 Notebook
V25 laptop will not turn on from battery power
The problem associated with Laptop not being able to power from the Battery, even if the Battery is new, can be attribute to the mainboard charging Electronic. The charging electronic in Mainboard is perharps defect. If your laptop still have warranty, this is the best time to change the mainboard.If not, seek for a qualified technician to check the PC, run the system, make Bios Update, and have the mainboard checked.
Nov 08, 2008 | Samsung V25 XVC 2800 Notebook
Hi, i have a samsung v25 laptop and there is a problem with the charging. the power adaptor flickers on and off when it is plugged into the laptop causing it not to charge properly. when it is not...
This is a problem with the power adapter that you may need to replace it already since that is causing the laptop not to work properly.
Hope that helps..........
Aug 14, 2008 | Computers & Internet
BATTERY FOR SAMSUNG V25 MODEL NO. NV25NH0VM3/SUK
I ask my frend if they have a battery + charges of your Laptop.
i get already the information.
Aug 10, 2008 | Samsung V25 XVC 2800 Notebook
Samsung v25 laptop
open your laptop back side.
the ram is on the battery position.
replace it.
Apr 02, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 2600XPP (NV25NP0SJM/SUK) PC Notebook Logo
66 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
