SONY BRAVIA KLV-S32A10E LCD TV. Screen is filled with multicolour small pixels.
LCD TV screen is covered by many small multicoloured pixels. They are all over the whole screen with equals space/gap between each pixel. All inputs including PC input using computer and Audio Video input with DVD player are showing the multicolour pixels on top of the input/tv channel pictures. However upon showing the menu, the pixels seems to be pulled from the whole screen and cover only slightly more of the size of the menu window on the screen. Any ideas where the problem lies? Thank you for your assistance.
  • Movi Jan 11, 2013
    This TV should be similar to KLV-S32A10. My guess is the "E" at the end only to represent European version. I have posted some pictures to view the problems.
zjut
  • 106 Answers
SOURCE: Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Posted on Jan 01, 2008
SOURCE: plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Posted on Jan 01, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia 40inch LCD Digital TV
Its very easy, pick TV original remote and press " i " (info) button on remote and on-screen display will disappear.
Have a great day.
Posted on Apr 03, 2009
  • 5 Answers
SOURCE: Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
Posted on Jul 30, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
LED TV double omage Sony Bravia KLV-32S 550A
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Aug 21, 2016 | Sony KLV32S550A 32 LCD TV
I brought Sony Bravia KLV-32U300A 32 in. HD-Ready LCD TV 4 years ago now it's screen fill with lots of tiny lines difficult to see pictures. i submitted it to service man. he told me problem is on...
This is the main fault, that most Sony LCD TVs. The actual cause is with a faulty T'Con board. For most Sony LCD sets, this part [T'Con board]; will be a built in part with its display panel, and can't be replaced. Display panel replacement is the only repair work. Nothing can be done, even for the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 03, 2016 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Dec 07, 2012 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
On my Sony Bravia KLV-S40A TV I have a message "VIDEO 1". How do I get it off the screen?
On the original SONY remote press display to remove that---if left on long enough it will actually burn that image into the screen--button on almost any Sony Tv remote will remove or clear it.
Oct 25, 2012 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Picture has multicolours and is like a colour
Picture has moving multicolours and is like a colour ngative on the samsung digital tv. Model la37a450c1
Aug 14, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
Nokia 6500: Dodgy screen?
simply check the connections of the lcd to the board... or just tighten the screws... i had repaired a phone of that problem and this was my solutions.
May 31, 2009 | Nokia 6500 Slide Cellular Phone
Sony KLV-40U100M Screen replacement
If this were just about any other brand, you'd likely be able to find another brand of TV with the same size screen and swap the inverter boards and the LVDS board. The problem with Sony is that the company uses internal designations. If you have homeowner's or renter's insurance, it might cover some of the cost. Otherwise, put the damaged set on eBay (you'll get a couple hundred dollars plus shipping) and go buy a new set. Likely, any larger set for sale with a good screen is going to go for more on eBay and finding one is rare.
Jan 31, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
Electro Med Services...
