Question about Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA) Network Adapter
IP ADDRESS OF VOIP PHONE ADAPTER 2 PORT PAP2NA
I NEED IP ADDRRESS FOR INSTTLE THIS VOIP PHONE ADAPTER 2 PORT PAP2NA PLEASE HELP ME
    Guru:
  • 825 Answers
Take phone receiver that is connected to linksys... press * key 4 times, it will take you to configuration menu... Now press 110#... it will tell you the ip address...
Posted on Feb 08, 2011
  • 39 Answers
Doanload colosoft netscan, when you have it plugged into the network, run netscan on a computer thats on the same network....that'll find it for you, if that doesnt work give me the specs on the phone and ill check the manuels..
Posted on Jan 26, 2009
How to get the ip adress from a linksys rtp300 phone adapter
I'm not sure if your asking for the IP ADDRESS of your Linksys or the DEFAULT GATEWAY of that device because your router's ip address will be provided by your server or Internet Service Provider (ISP) depending on your service. There are two ways of obtaining an ip address first will be DYNAMIC, where your ip address changes all the time and STATIC where you are given specific ip addresses for example 192.168.0.1 -to 192.168.0.25. The easiest way to obtain those ip addresses, by the way, is to contact your Internet Service Provider (ISP)
example: AT&T, Roadrunner, Time Warner, etc....
But, if your looking for the DEFAULT GATEWAY for you to access your router's configuration, most of the time it is found underneath the router itself. For Linksys the Default Gateway is 192.168.1.1
>I hope i helped you out with this... Enjoy!
Sep 15, 2010 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
I am getting engage tone when connecting linsys
i have Spa 2120 it problem line phone it has get ip address but the phone line is not caming could you help me that problem.
thank you,
Dec 24, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
I'M TRYING TO PUT THIS IP NO192.168.1.101 BUT I'M NOT GETTING ANYTHING, CAN YOU EXPLAIN PLS
You need to know the configuration of IP addresses that your router supports. My guess is that IP is a computer on your local network.
Sep 13, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
IP address
your voip enabled phone uses dynamic ip addressing so doesn't have a fixed ip. however if you want to configure the phone Connect the WAN port of the SPA922 to your network (router, switch or hub). Make sure that you have a DHCP server so that the SPA922 will get the IP address.
To login to web based administration follow the steps
Access the web based setup page of the SPA922. Verify the IP address through the LCD. Click Menu then press 9. It should show you the DHCP IP address. Open a browser and type that in the Address bar.
Click Admin Login .
Note: The SPA922 does not have a username and password by default. If you are asked for a username and password and you have not configured a password, it means that the SPA921 is locked by your VoIP provider. You need to obtain the password from your VoIP provider.
if this helps resolve your issue please vote for me. thank for using fixya.
Aug 10, 2009 | Linksys SPA922 IP Phone
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
Linksys RTP300 Broadband VOIP router W/2 phone ports
Have you tried to do a hard reset on the unit?
Apr 05, 2009 | Computers & Internet
No Dial Tone--Update E911 service address?
1) What make and model of VOIP adapter is it? (Most all manufacturers put the manuals on their website).
2) Do you have a VOIP account for the adapter to register to?
Jan 15, 2009 | 8x8 Packet8 Broadband Phone Service...
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Port forwarding
try this.
1.Access setuppge of the router through http://192.168.1.1
2.User name admin Password is password
3.Once you are int he setup page on the left side click port forwarding
4.You may need to ask linksys what are the ports needed to open for the PAP2 device that you have aqnd get its IP address.
Apr 18, 2008 | NetGear WGR614 Router
Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA) Network Adapter Logo
418 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
