Set cycles, push start and it shuts off - Washing Machines
  • janiev
    janiev Jan 12, 2013
    the washer will work on the rinse/drain & spin cycle and also clean washer.
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 12, 2013
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
Washer will not shut off.
sounds like the final phase is not being registered on the timer or the computer chip may need to have a service tech diagnose but it isn't a complex problem just an annoying one, the final phase is a cool down cycle and also you may need to see if you have the settings for cotton clothes, the dryer will tumble them so as not to let them wrinkle. hope this helps
May 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Car restarts after automatic shut off
When you use your remote start system the vehicle will run aprox. 15min. ( depends on your settings,check your manual) But will go thru a cycle and shut it self off and then restart the vehicle again until you either push the remote stop button,depress the brake,open the hood or insert the key.
Dec 27, 2009 | Python Vehicle Parts & Accessories
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Maytag neptune,shuts down within 10 seconds after start button is pushed
If it has worked for a year and your able to choose different cycles with the same result. It seems to functions with one common element failing. If the control unit cant detect how full the machine is with water it will shut down. Sounds like a water problem steming from your pressure switch. Not sure which model you have but usually it will sit on the water pump or under the console with a clear hose if under the console. If so a quick test of attaching an ohm meter set on continuity then blowing lightly to see if under pressure the switch reacts by closing if it doesnt then the switch is bad.
Sep 16, 2008 | Washing Machines
Kenmore dryer
IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
Apr 01, 2008 | Kenmore 62602 Electric Dryer
Self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
Feb 10, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Kenmore C11084 7029 0 dryer will not start
replace the main motor you have bad motor
Nov 12, 2007 | Dryers
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Wont start
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Feb 13, 2007 | Frigidaire 24 in. FDB1051RE Built-in...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
