Question about Microwave Ovens
Panasonic microwave Genius sensor 1250W error code H97
3 Suggested Answers
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Posted on Apr 24, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Inverter Genius Sensor 1250W reads code H97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Nov 03, 2012
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
Aug 23, 2017 | Panasonic Microwave Ovens
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
Panasonic inverter 900w microwave fault code h97
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Nov 02, 2012 | Microwave Ovens
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Feb 09, 2010 | Panasonic Microwave Ovens
Error code H-98
Dec 01, 2008 | Panasonic NN-P794SF Microwave Oven
Microwave Ovens Logo
509 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
