Hi i have a samsung le40a656a1fxxu and there has lines down the srceen after about 2 mins the picture comes on ok but u can just see the lines sill if u put the menu up the lines are up and down over the menu but u can sill see it do u think this is the tcon board gone thanks for any help martin
  • 191 Answers
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
for bn94-00963b go and change your backlight inverter
Posted on Oct 05, 2008
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
  • 304 Answers
SOURCE: Hello, I have a Samsung LN-S4692D.
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
Posted on Apr 16, 2010
  • 6 Answers
SOURCE: HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
Posted on May 26, 2010
SOURCE: Hi, Maxent P420142x3. Screen picture has gone....
my maxent p420142x3 i have sound but no picture any answers
Posted on Jun 29, 2010
My Samsung LE40A656A1FXXU is not coming on just making a sleep mode noise very 10 seconds
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 05, 2016 | Samsung Televison & Video
My LCD tv loses picture for a couple seconds but then comes back on. How do i fix this?
Hi Noah, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=cI2L61dzj6k
Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
Apr 30, 2016 | Samsung Televison & Video
Tv turns on ok,first displays black screen with 2 horisontal lines and some static at the top,than slowly from the top down i can see picture,after 5 min i can wacht tv but i have 2 lines -horisontal and...
Hi Marcin,
First of all, thank you for posting your question here at Fixya.
To diagnose accurately the exact caused of the symptoms, please let me know the Brand and model/chassis number of your unit. It is printed at the rear panel, manual and on the receipt. It will help to narrow down the symptoms and locate the availability of parts online.
Jdvillanueva
Jan 20, 2012 | Televison & Video
Hi We have a Samsung Tv LE40A656A1FXXU flatscreen keeps sticking in stand by mode. The red light is flashing and sounds as if its turning on but takes a while, eventually it does come on and all is fine...
The problem is that there is a bad capacitor on the power supply board of the television, it is still turning on because it is not yet completely bad. While it tries to respond is when you get the clicking sound, therefore it is going to keep acting that way until the bad capacitor is replaced.
Run a check on the power supply board, you will definitely see the bad capacitor, have it replaced and the television will turn on after reassembling the television back together.
Thank you for using fixya
Caseytech
Jun 29, 2011 | Televison & Video
I have lg ru50pz61 plasma after turning on after ABOUT 20 MINS I LOSE HALF THE SRCEEN PICTURE IT STARTS TO JUMP THEN I HAVE LINES AND NO PICTURE YOU CAN SEE THEN AFTER ABOUT OTHER TEN MINS TH HOLD SCREEN...
If it's under warranty have it return to the supplier for replacement. It's hard to diagnose the problem without opening your TV. It could be the vertical IC that is usually a problem in most CRT. It's really hard to tell without scanning the board. Best thing is to bring it to the tech shop near you
Mar 26, 2011 | LG Televison & Video
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Sill supports for window air conditioner...no sills
ok do not worry...every unit comes with outside supports that allow you to tilt the uinit to the outside a little so the water discharge can leake outside and not inside your house...one support go in eachside under th eunit one side connect to the wall and the other side connect to the bottom of the unit...
the whole is need on the side you are going to let the water out...the unis discharge lots of water and need a way out and the hole is for that make suer it is on the back close to the corner and far away from any moving part.(I usually find a place under the fan that is if they do not have one pre-driled
Sep 07, 2009 | Heating & Cooling
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
