Question about Vacuums
Model: EL1014A SKU: 9274625 - owner manual for Electrolux Ergorapido vacuum stick 2 in 1
SOURCE: I bought an Ergorapido stick
try here Ginette
http://electroluxservice.stores.yahoo.net/prontofilter.html
Andy
arbear@shaw.ca
Edmonton, AB
Posted on Aug 19, 2008
  • 21 Answers
SOURCE: My electrolux ergorapido wont power on.
If it will not come on there are several things you need to check. First off you should call and have your model type and serial number checked to be sure your unit isnt affected by the recall they had due to expanding batteries. Second you do have a 2 year warranty on the unit and if it wont even turn on there may be a defect. Are the blue charging lights coming on? If they are and your transformer is warm then there is more then likely a defective battery in the unit and you should contact customer service at 1800-896-9756
Posted on Jul 19, 2009
  • 21 Answers
SOURCE: Need a belt for Pronto 2 in 1 stick vacuum.
Your not gonna find a belt because the belts on these units are not designed to be replaced by the consumer and would need to go to a service station
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
EwingElect
  • 276 Answers
SOURCE: Where can I obtain a free manual for the
If it's one that look like the one pictured, it's called another name in Australia, but the premise would be the same. Try
http://www.electrolux.com.au/Files/australia_english/Manuals/Cleaning_2007/ZB2812-ZB2813-ZB2815Instructions.pdf
Regards
Posted on May 25, 2010
Will not maintained power in high setting. Runs fine in low power setting.
I would recommend thoroughly cleaning all filters, most likely the high setting is overheating the motor and the thermal protection circuit is tripping. In other words, the motor isn't "breathing" well.
Mar 15, 2016 | Electrolux 2-in-1 Stick Handheld Vacuum,...
Where do I find the serial number please
Not all items made by Eureka have serial numbers. Unless its a high end machine, there won't be a serial number. You will only find a model number which is just a general number defining what model the machine is.
Oct 01, 2015 | Electrolux 2-in-1 Stick Handheld Vacuum,...
Electrolux ergorapido plus
Christmas 2013 I was given an Electrolux ergorapido. I put it on the charger and red light won't come on or if it by chance does it flashes three times and then cuts off.
Aug 13, 2013 | Vacuums
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
My electrolux ergorapido does not seem to have much suction, it is also very quiet. is this just the way it is?? i am the second owner, i have cleaned everything.
I took mine completely apart, removing every screw to get to the motor which was full of lint, hair and god knows what. I removed all the debris I could by hand, put it back together, and it works like new. I think debris gets in if the filter part is pushed too far down and the hole in the cup is open to the top part. My husband wanted to throw it out but I figured "what the heck". It's broken, it won't get more broken if I take it apart, it's only a year old.
May 09, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
My electrolux ergorapido wont power on . Have only used it a few times. It has been on the charger for approximately 2 weeks without use.
Jul 18, 2009 | Black & Decker AV1200 DustBuster Handheld...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
