Question about Burton Ruler Snowboard Boot (Men) 11
Lace loop at bottom broke off - Burton Ruler Snowboard Boot (Men) 11
  • Julian Jan 11, 2013
    Im not sure on how i can reconnect it.. It's a plastic bit and the surrounding is leather-type material. I just dont want to tighten my boot too much where it will come loose then it's not comfortable
What size laces do I need for my rocky boots?
Take something like dental floss and run it through the lace holes. Cut at the length you want, then measure the length of the floss.
Jan 21, 2015 | Rocky Mountain Bicycle Company Cycling
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
Rapid lace system problems.. uneven lace
Hi All,
I had an uneven problem with the DC Siloh '09s. Not sure if it will cover all makes and models but I will explain how I fixed it.
Key for the instructions:
Numbering the laces from top to bottom 1-8, outer side of the boot = little toe, innerside = big toe, and on the two laces that lock on either side of the boot (4 in total) toe and heel lace.
1. In order to make the laces even again you need to unlock the heelside lace on the outerside of your boot, this lace controls lace 3.
2. Pull lace 3 using creating slack now that it is unlocked
3. Pull the slack through lace 4 and then 5.
4. Once you have slack in lace 5 unlock the toe side lace on the inner side of your boot.
5. Holding that same lace pull the slack through the locking mechanism until you are happy with the balance.
For moving slackness from the inner to the outerside the opposite approach applies.
If it is not clear, reply and I'll try and take a photo or post a video or something.
Cheers
Mikey
Aug 12, 2012 | DC Shoes DC Methvin Snowboard Boot Men
I ran over a shoe lace and the brush on my dyson quit rotating how do i get it going again?
Turn it off and turn it back on again and it should reset.If that dosent work you probably broke the belt.It's easy enough to replace by just removing the bottom plate and the brush and installing the new belt. www.sewvac.com
Jan 29, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Tl98e broke a needle and now won't stop looping.
needle plate may be sanded lightly for nicks and scratches. Timing is probably off, need to see an expert repair service in your area.
May 30, 2010 | Feiyue FS288
My Burton boots are loose around the ankle and the laces do not stay tight. Any recommendation would be appreciated.
For the ankle you may need some specially shaped foam inserted between the boot outer and the liner to take up the space. This can be done at any good snow store. As for the laces make sure that when lace up in the morning lace the boots all the way to the top and when you reach the top, while holding the laces, flex in the boot a few times and kick your heel against the ground to make your your foot in snug (this may also help issue #1. Once you have done this, pull up hard again on the laces and loop them once around the top before tying a double knot.
Mar 12, 2010 | Burton Winter Sports
I am unable to loosen the laces on the exterior of the boot. Only the bottom half is loose and the top three laces remain very tight.....as if there is a knot inside the boot lining.
Sometimes if the boots have been well worn the lace will pill inside its tubing and become stuck. The best way to fix this is to untie the jammed lace at the bottom and then pull from the top to remove the damaged lace. You will also need to get a replacement lace from your Burton store to repair in reverse.
Feb 11, 2010 | Burton Moto Men's Snowboard Boots '09
I have a De Dietrich dishwasher (VZ9996U1)with a broken plastic loop which holds the side door spring. Can I get a new plastic loop? This loop is also attached to a length of cord. Alison
Same thing happened to mine - I simply took some nylon cord, about the thickness of a shoe lace and made a slip knot loop around the remaining cord. (the plastic bit was still attached and the knot pulled up against this). this has been working fine ever since.
Dec 30, 2009 | De Dietrich Dishwashers
How do i string the net
http://www.littletikes.com/pdf/4612 10_98.pdf
this is the manual for your item.
To lace the net, take top of each loop, slide it up thru each center hole and spead it over the two end pins.
See pics # 10 & #11
eNJOY AND HAVE A HAPPY HOLIDAY
Dec 12, 2009 | Little Tikes Totsports Easy Score...
BOBBIN TREAD LOOPING UNDERNEATH
looping thread on the bobbin side means that the upper tension is too loose... make sure it's threaded correctly.
Jun 14, 2009 | Feiyue FS288
Burton Ruler Snowboard Boot (Men) 11 Logo
88 people viewed this question
Top Burton Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
