Question about GE 30 in. Profile JP938 Electric Cooktop
2 burners not working
I get Error 123 and Error 143 when I try to turn the burners on. Then, the Lock light comes on. I have turned the circuit breaker OFF, but it does not help.
Pilot lock light on stove is on so stove burners unable to work
This sounds like you may have to fix a problem in the pilot area before it will work. These gas operated devices have to meet a much higher safety standard than their electric counterparts. It is a built- in safety feature. Now, look for any obstruction or crimp in the gas line. My guess is you are not getting proper gas flow or pressure or the pilot could be physically blocked.
Feb 19, 2015 | Thermador Cooktops
GE Profile mod. PP975bM3BB all lights work Burner will not heat
You have lost half of the circuit in the breaker, the lights work on one side of it but the burners need both sides of a 220 volt circuit. I would have the breaker tested first, and if it is good, look for a fuse, relay, breaker in the back of the stove. Hope this helps.
Mar 06, 2012 | GE Profile 36" Electric Induction Cooktop...
Miele LP cooktop: we turned the power to the range off. when we turned on again it didn't ignite (it has power!)
Hello
Keep the air holes around the burners free of debris and grease by clearing out the holes with a thin piece of wire or a toothpick. Cleaning out the holes helps the ignitor light the cooktop
Listen for the clicking sound of the ignitor, then turn off the burner if you don't hear the clicking.
Turn the burner to the "Off" position, if you continue to hear the ignitor tick after you've lit the burner. Turn the burner back on to relight it. Ignitors normally make a brief series of electrical clicking sounds when you turn on the ignitors.
Let the ceramic igniter dry out if it has gotten wet and the burner won't ignite. If the igniter isn't wet, clear out the little holes in the burner by chipping out any blockage with a straightened paper clip.
Clean the electrodes if the burners still don't light. The electrode is in the burner base. Clean the metal part with a soft cloth. You can use emery board on the metal part but not the white ceramic part.
Nov 03, 2010 | Miele 30 in. KM443 Electric Cooktop
The cooktop will not turn on. The little red light in the lower right corner of the touch panel is blinking. If one touches and holds it it does not turn on a burner per usual. The timer function works....
I'm going to assume this is a new installation, either way, it sounds as if you're only getting one leg of your 220v circuit, which wld run the timer and lights but not enough to power the burners. This is prly not something you shld try and repair yourself as a 220v circuit can cause some serious damage. At the least, you could first, TURN OFF THE BREAKER and then check the connections to the cooktop to make sure all connections are secure.
Jun 11, 2010 | Gaggenau CK 171 28 in. Electric Cooktop
Ignitor does not spark on first turn as stated in manual. I have to turn the knob past "lite" before flame comes on.
Is it just one burner knob that does that are all of them? If it is just one then the igniter switch built into the burner knob might be out of alignment or loose. This happens most of the time due to a cracked switch housing(made of plastic). This can also happen if the actual burner knob is cracked and/or loose. If all the burners do this then it is just the way the cooktop works. The best way to get the burners to light is by slowly turning them on until they light and not pay attention to the "light" mark. You might need to turn it just past the "light" mark for the burner to come on.
Jan 18, 2010 | GE 30 in. JGP326 Gas Cooktop
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
The "lock out" button will not release to allow burners to come on for use.
Try turning off circuit breaker for about 2-3 minutes.
This should reset the main PCB.
If not contact dacor customer service @
800-793-0093
Jan 09, 2010 | Dacor Millennia ETT365 Electric Cooktop
Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Jan 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Jenn-Air JED8430BDB blowing fuse following ceiling fan work ...OUTside!
You have posted this to a public webpage that has 7 million visitors and is nothing to do with your electrician 'Eddie'. You have also posted your telephone number and email address to those 7 million viewers.
Feb 27, 2017 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
GE 30 in. Profile JP938 Electric Cooktop Logo
22 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
