Question about Kenmore Washing Machines
Taking tub out of sears 80 series washing machine
Trying to get tub out
  • Kenmore Master
  • 17,130 Answers
Please check this link for tips to remove the drum.
click on Drum removal
Posted on Jan 12, 2013
  • 209 Answers
SOURCE: kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Posted on Oct 14, 2007
jsrock516
  • 5911 Answers
SOURCE: Washing machine will not drain/go into spin cycle
Check your lid switch. If the lid switch is not making proper contact, or is broken, the washer will fill, agitate (some model washers won't), then just stop when it gets to the spin cycle. If this is what you are experiencing, then this could be a quick and easy repair for you.
Try opening an closing the lid. If you don't hear a clicking noise when the lid closes, the lid switch may be bad or loose. It is mounted under the opening of the tub rim on the right-hand side and held in place with two screws. Make sure the lid strike ( a small plastic piece) is present on the lid as well. This closes the switch contacts when the lid closes. If the lid switch does not function, the washer will not complete a wash cycle.
If the determine the switch and/or lid strike is broken, searspartsdirect.com carries the parts need. Just type in the model number you provided and you will find the lid switch under the "Top and Cabinet" heading as item #11 (part #3949238). The Lid Strike is under the same heading as item #20 (part #350733).
If you need advice on how to replace the lid switch please post back and let me know.
If I'm off the mark here, please post back with comments and give me a little more elaboration on what your washer is doing or not doing.
PS You do not need to drain the tub to replace the switch. If you wish to drain it, however, and want to by-pass the lid switch, I can give you instructions on how to do this as well.
Posted on Apr 14, 2008
SOURCE: How do I take apart
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Posted on Aug 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
SOURCE: Sears Kenmore 80 series washing machine Model 110.26832691
How do you remove the top of a kenmore washing machine? I have a mouse stuck in the lid and can not get the top off.
Posted on Apr 30, 2009
Washing machine tub not supported
the 80 series kenmore tub is supported by springs depending on its age they may be worn
Mar 19, 2013 | Washing Machines
Taking washer tub out of sears model
Please check on this link for tips to remove the tub: Removing Drum
Jan 11, 2013 | Washing Machines
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I get oil stains on some items of clothing in each wash. I've tried discontinuing use of fabric softener as suggested by Sears, and I've also tried several loads of CLR to clean any grime or rust build up....
If this is a front loader, it is the bearings on the tub shaft. I just replaced a set on my front loader for the 2nd time. It is not a real easy fix but mine cost only cost 25.00 for the 2 bearings and seal. Not from Sears.
Jun 28, 2009 | Kenmore Washing Machines
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
May 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
