Question about Whirlpool Duet GHW9150P Front Load Washer
How to clean pump on whirlpool duet
Model wfwg8300s02???
  • Whirlpool Master
  • 17,129 Answers
If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Posted on Jan 12, 2013
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport Model WFW8300SW00 stops after spin cycle
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
  • 7 Answers
SOURCE: where is the model number found on duet?
When you open the door it is on the frame
Posted on May 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 28, 2010
My front load whirlpool washing machine got to spin cylce and stopped. The door wouldn't unlock and the light showed add garments but it hadn't finished spinning the others any suggestions?
Your drain pump filter probably needs cleaned. YouTube has several videos you can watch on how to do it. It's an easy fix. Type " whirlpool duet drain pump " into the search bar. Let me know if you have trouble.
Jan 12, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Getting the F35 error on Whirlpool Duet washer model WFW9500TC01. Can you provide troubleshooting help? Thanks!
Follow other instructions for replacing the pressure switch. or better yet. Take it to the scrap yard and get something out of it. That is where mine is going tomorrow, Whirlpool is far overrated with the poor quality and design of products they make. I removed the entire back from mine and noticed a piece of the concrete that is used for counter balance was broke. and the drain pump makes an evil clicking noise. and it doesnt help to pull the drain pump, clean out trap, and reinstall drain pump.. What a 226 pound pile of ****. Whirlpool you should be ashamed of your self to have this many problems with your duet "WHAT A **** JOKE" I WOULDNT HAVE ANOTHER WHIRLPOOL IF THEY WERE $5 on clearance.
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clean pump
If this is a Whirlpool Duet model washer, the following link explains step-by-step, how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If this is not the model washer you have, or if you require additional assistance, please post back and let me know. I hope this is helpful to you.
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Not draining
how do i unclog the drain pump
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i clean the pump filter on a duet washer
take the kick panel off. dead center you will see it
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
775 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
