Question about Vac Buggy CB962 Canister Vacuum
I need a filter for my Vac Buggy CB962
Where do Ifind replacement filter for my wet dry shop vac
tons of sellers on Amazon with good prices. just make sure you get one for "wet" if you plan to vac liquids.
Feb 21, 2015 | Shop Vac Vacuums
WHERE CAN I BUY THE HOSE FOR THIS MACHINE?
You can probably find a universal hose at one of the Big Box hardware stores.
May 07, 2011 | Vac Buggy CB962 Canister Vacuum
New vac no instuction manual . i need to vaccumn
No you do not need the filter to pick up glass. If you are vacuuming up dust/dirt then use the filter.
Jan 22, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vac doesn't work well after cleaning
check your filter
it the round thing hanging from the middle
you may need to clean or replace your filter
you should never leave the filter in while using it as a wet vac that will ruin it immedatly
Oct 09, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vac Buggy CB962 Canister Vacuum Logo
163 people viewed this question
Top Vac Buggy Vacuums Experts
Are you a Vac Buggy Vacuum Expert? Answer questions, earn points and help others
