Question about NRS Stex 8025TL Attachable 17 Inch Lcd Tv Treadmill
Belt is slipping, even on the lowest power.
The Stex 8025TL is currently in Iraq with the marines. There is no owners manual and the belt is slipping, even on the .5 mph setting. It really needs to be cleaned also. It was being used on a daily basis and probably more than normally expected, but we think we can get it back to operation with instructions. Is there anywhere we can download an owners/repair manual so we can at least start in the right direction. Thanks for your time and assistance.
    New Friend:
Hi My name is Max..email me at maxfitness@ymail.com if you need Stex manuals.
if you have tighten belt and it still slips, the belt and deck need replacing.
Posted on Jun 18, 2014
  • 83 Answers
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
As far as the manual, I have not been able to found it anywhere yet.
Posted on Apr 30, 2010
Hydraulic system
I would say,that the Motion Drive Belt,has stretched to the point,that it is slipping on the pulleys. Over time all belts stretch or break. There is no adjustment,that can be made,once stretched,its time for a new belt. Look in your Owner's Manual,to see,a picture and directions of how to remove and replace a motion drive belt. If there isn't a picture of the drive belt in your manual,then look under the left foot rest. There you will find a decal,showing the correct method to install the belt over the pulleys. This is going to be a long belt,it runs from the Transaxle to the motor's upper pulley assembly. You can,it will be hard to do,remove and replace the drive belt with the mower deck attached. First,try lowering the mower deck,to the lowest position. This will give some room,to get to the motion belt,you will have to remove the mower belt,to get to the motion belt. I find it is easier to just remove the mower deck entirely. Doing this,give you ample room to work on the motion belt. The mower belt,can be purchased from Sears Parts Direct. Give them the tractor's Model Number and the Belt Part #,if you have the number,they will look it up anyway,if not. I gave more information,than you asked for. I hope this will help you. Sincerely,Brad Locke DTD. 12/04/15
Jul 15, 2013 | Sears Craftsman 46 in Mulching Tractor...
Stex treadmill about error 2
adjust the Speed sensor, see the diagram, clean it, test for open or faulty, and tight the connector very well.
Lube the deck belt, see the video, lube the rollers bearing front+back too , test the drive belt motor and replace the belt if necessary. God bless you
However you must try to Run the software calibration after your fix it.4d80cf2e-89d9-4476-902b-88e5991886e8.gif
Jul 03, 2013 | NRS Stex 8020T Treadmill
My belt keep slipping. And I try tighten the ajustment bolts.
Make sure you adjust vthe motor belt first, it may be where the slipping is coming from. You should only be able to twist a properly tightened motor belt 45 degrees. After that, readjust the walk belt. If you have been tightening the walk belt trying to get the slipping out it may be too tight now. Use the instructions in your owners manual to adjust the walk belt. Also, lube under walk belt with the recommended lubrication . That will help the walk belt not too grab and take pressue off of both belts. Good luck
Mar 15, 2011 | Horizon Exercise & Fitness
Need info on changing belt, no longer have maual
You will need a Phillips screwdriver and a new belt.
Unplug the vacuum, lower handle to lowest position, and turn it over so the bottom of the power head is up.
Remove the screws from the bottom plate and lift it off.
Remove the flat (outer) belt, or any fragments.
Slip new belt on to motor shaft, then over the large pulley. It's easier to get the belt over the pulley if you spin the pulley toward the brush while doing so.
Diagrams and information are found in the manual.
Click on the below link to get a downloadable copy of the manual. You can print it from there as well. How to change the flat belt is on page 10. The V-belt is on page 11.
http://www.hoover.com/pdfs/manuals/U6616900.pdf
Mar 02, 2011 | Hoover U6616-900 WindTunnel Bagless...
I have a 1997 Toyota Corolla, it sounds as if the belts are slipping and I'd like to replace them myself. From doing some research it seems that there are 3 belts: alternator belt, power steering belt and...
Well if your sure that it really is the belts the job isnt too hard. Refer to your owners manual for a clear view on how to replace them. I feel that every car owner should own a car manual for the car that they own cause they really do come in handy and are very informative. My question for you is how did you determine that it is your belts that are making the slipping sound? An oil pump that is no longer pumping oil will cause your engine to make almost the same sound and the squeal that you hear is the cylinders lacking lubrication. You might want to check your oil pressure just in case.
Nov 17, 2010 | 1997 Toyota Corolla
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
Driver belt is starting to slip and squel when
that's not something she's going to be able to fix,unless she's real mechanically inclined. If you don't trust shop's take it to pep boy's or the dealer. They won't hose you.
May 04, 2010 | 2005 Mitsubishi Lancer
Treadmill Stex 8020 when switched on immediately increases speed on board (without touching buttons) until it reaches 250km...the belt isn't moving when this is happening and pressing + or - or other...
If it reaches 250km then I suspect that the upper electronics is not functioning properly contact the distributor of Stex and If under warranty they sould cover it,but send out a servicer
May 03, 2010 | NRS Stex 8020T Treadmill
NRS Stex 8025TL Attachable 17 Inch Lcd Tv Treadmill Logo
161 people viewed this question
Top NRS Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
