Question about Uniden DECT 6.0 Cordless Phone ID
Uniden dect 6-0 says its out of range but its by the base
I dont have the manual but the nuber on the back by the battery isBW7018589
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Make sure the handset is registered to the base. Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Jan 12, 2013
cnavarro
  • 2460 Answers
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Posted on Aug 27, 2008
SOURCE: Phone says "Searching" and will not work.
como activar mute la pertada 2 sin vos
Posted on Jun 24, 2008
SOURCE: uniden dect 6.00
handset dies or cuts off frequently during calls or when talk is pressed to answer even when fully charged and right in front of the base unit. Beyond frustrating.
If I hadn't lost the reciept, I'd return this useless phone in an instant.
Posted on Sep 03, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
How do I find messages/mute?
To hear your messages, press PLAY on the base.
To mute, press CLEAR on the base.
See pages 22 and 6 of the manual: Owners Manual User Guide for Uniden Dect2188 3 Dect 6 0 Cord cordless...
Feb 22, 2015 | Uniden Dect2188-3 Dect 6.0 Cord/cordless...
My handset is display only searching, I cannot make or recieve calls & it is just flashing 88
when I press talk I get connectin9..handset out of range..searcgin9
when I press end I get Searching
Jan 30, 2013 | Uniden DECT 6.0 Cordless Phone
Handset says searching
Searching means its searching for a signal. If the phone cant contact the base it will say searching. Make sure the handset is in range of the base and the base is connected to the power.
May 16, 2012 | Uniden DECT 6.0 Cordless Phone ID
Model6.0shows out of range or no power at base i have lost book e manuel
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only suggest that you select it from the list beginning here to download a copy of the manual.
Apr 08, 2012 | Uniden DECT 6.0 Cordless Telephone...
Why is handset reading out of range? OR searching?
THAT HAPPENS WHEN YOU DROP THE PHONE TOO MUCH.
THE SOLUTION IS TO TURN OF THE BASE FOR 2 MINUTES.
THEN REMOVE ALL THE PHONE BATTERIES. ALL OF THEM
WAIT FOR MINUTES,
PUT THE BASE BACK FIRST, PUT ALL OF THE PHONES BATTERY BACK
PRESS THE RED BUTTON, YOU WILL SEE THE "OUT OF RANGE RANGE" MESSAGE AGAIN.
IGNORE IT AND PRESS THE GREEN BUTTON. HERE YOU GO.
MAKE SURE TO CHARGE IT AFTER THIS.
PLEASE RATE IF THIS SOLVED YOUR PROBLEM
Apr 12, 2011 | Uniden DECT 6.0 Cordless Phone ID
Phone Not Working
Remove the battery from the back, wait 1 minute, then replace the battery. DO NOT HIT ANY BUTTONS. place the phone back on the main base unit so it can reregister.
Apr 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
My uniden dect 6.0 model# 2088 base doesn't display anything and the handset says out of range
disconnect the battry and the phone like from the base and the phone(s) and them put them back together and see if it works.
Mar 12, 2010 | Uniden DECT-2088-2 1.9 GHz Twin 1-Line...
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden DECT 6.0 Cordless Phone ID Logo
421 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
