Question about Frigidaire Refrigerators
Frigidaire plhs267zcb2 side by side refrigerator not cooling on either side
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: Frigidaire FRS26ZSGRefrigerator is no longer
Your auto defrost is not working. remove the rear assembly inside the freezer and melt any builtup ice with a hair dryer. Then check the defrost heater and the defrost thermostat. If OK then check the defrost timer located either in the fridge compartment behind the temp control or under fridge in frount behind grill. A continuity test is good for timer contacts. Heater is typ. 30 - 40 ohms. Thermostat will read short short below 35 degrees and open above 45 degrees. Timer motor winding has a series capacitor and must be tested as such. Watch out for stalled or slow running motors that look OK. PS. : QUICK TEST - The timer can be turned with a screw driver through a service access hole. With the back - of - freezer plate off turn timer till it clicks and you hear compressor turn off, this is the defrost cycle (7-10min). Use it to see if the heater is getting hot.
Posted on Mar 12, 2009
  • 534 Answers
SOURCE: Refrigerator side will not cool on Frigidair
2 things could be the problem.. 1 check to see if the fan located on the temp. setting control assembly is working. If this fan is not on the fridge will not cool. if the fan isn't working replace it and problem should be taken care of. If fan is working then your defroster is out.. You can tell if defroster is out due to the big chunk of ice in space between the fridge and freezer where the fan is also located. Parts can be purchased at an appliance parts houseand aren't that hard to install. Good Luck
Dave
Posted on Jul 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Describe your Frigidaire FSC23R5DSB Side by Side
That is the first sign of not defrosting. Look into the rear panel in back of freezer and see if frost is forming on that back panel. If yes then you will need to unplug and remove that panel to inspect the defrost heater and defrost thermostat. If they check out then we need to inspect both sides of the mother control board for burn marks or signs of heat damage. The 1467835 Control Board is located on the back and enclosed inside a plastic housing. The same circuit board also list as part number 241511101 Check the freezer first to see if the defrost heater may be bad. Need an OHM meter and take one wire off of one end to test. I will walk you through this if you want, Sea Breeze
Posted on Aug 21, 2009
  • 110 Answers
SOURCE: Refrigerator not cooling
No, the compressor does not have a manual reset switch on it. The first thing to do would be to check the breaker or fuse box. Make sure everything is on. Then with a voltmeter, check the wall outlet to make sure you have power. If you do have power and the refrigerator isn't turning on at all, you may have to have someone with electrical experience take a look at it.
Posted on Apr 02, 2010
Model plhs267zcb2 evap fan keeps starting and stopping continuously
Hello friend, thank you for your post!
I understand that your evaporator fan keeps starting and stopping on your Frigidaire refrigerator, PLHS267ZCB2. It sounds like it could be an issue within the fan or control panel. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose your appliance. -Matt
Sep 10, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery's refrigerator side stopped cooling
In side by side units, the freezer side actually cools the refrigerator side by a damper door/switch. Contact a professional if you don't find any blockages in the door area, and the temp does not change.
Aug 12, 2012 | Frigidaire FRS23H7CS Side by Side...
Frigidaire FRS22ZRF side by side. Freezer works but the Frig isn't cooling. Anyone know what the problem could be?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Frigidaire FSC23F7D Side by Side...
FRS2625H - frigidaire gallery professional freezer is maintaining temperature but refrigerator is not - barely cool
heatman101
Apr 30, 2011 | Frigidaire FRS26H5AS Side by Side...
I have a frigidaire gallery side by side refrigerator. The freezer side seems to be working but the refrigerator is not cooling
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 13, 2011 | Frigidaire Refrigerators
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jul 23, 2010 | Frigidaire FRS26R4A Side by Side...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
FREEZER NOT FREEZING
I will be more than happy to help.  Read this first on Frigidaire Refrigerators.   Then if you have anymore questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Jun 30, 2008 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
50 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
