Question about Stiebel Eltron TEMPRA 12 Tankless Water Heater
Keeps tripping thermal shutdown - Stiebel Eltron TEMPRA 12 Tankless Water Heater
  • 51 Answers
Most of the time its just bad (thermo disk) thermal shutdown as you call it. If you dont have any hot water at all just unplug the two wires on that disck and stick them together,this bypass that disk. then have somebody turn on the hot water while you watch the heater for any problems. Let me back up just a little.
Before you do that you must know if its tripping while the water is flowing through the heater if it is then its a weak disk. If it trips a few seconds after the water is shut off then for some reason(usually a bad circuit board) the element is not shutting off and over heating the disk. That means the disk is doing its intended job. Do not bypass the disk ifit trips after the hot water is shut off at a faucet.
Posted on Jan 12, 2013
Reset button on a o smith keeps tripping
After the high limit trips once, it is no longer calibrated. Replace the upper stat and limit.
Mar 21, 2017 | Water Heaters
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
High temperature thermal cut-out has tripped
Type, model, brand, age of water heater, and general installation of water heater are unknown.
1) Electric tank-type water heater: replace thermostats and test elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Gas tank-type: replace gas control valve, clean air intake screen/ location varies by brand:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Tankless: call service technician, or replace tankless with tank-type and save money long-term.
4) Add comment and describe water heater using label located on side of unit, and include what you are doing to 'reset' the thermal cut-out.
Jan 04, 2013 | Water Heaters
How to take off the thermal couple off a ge sg40t12txk
1) Copy following links:
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
2) GE is made by Rheem, so air intake screen is located below the combustion burner, as is the TRD (thermal reset device).
3) Modern gas water heaters, the FVIR, or FV system will trip when air intake gets clogged with dust.
This will slow venting of hot combustion gasses, except burner is still burning same amount of fuel. Overheating occurs, and that trips FV system.
Other brands require cleaning air intake screen and possible replacement of gas control valve, or FV sensor, etc. Each model is different.
Rheem_GE overheating will trip TRD, and glass vial breaks, causing air intake to close. Glass vial must be replaced, and possibly the gas control valve replaced.
Dec 18, 2012 | Rheem 36" Water Heater Thermocouple Kit
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
I have a powerstar ae115 water heater that is 3 years old. The thermal cutout onthe left side keeps tripping. after shutting off the shower the temp on the top of the unit is reaching 185*f. I have...
You've done the required first-step troubleshooting and maintenance.
If thermal cutout keeps tripping, and unit is actually reaching 185, then something is wrong with wiring, temperature sensor, gas valve, or PC board. Or combination of factors.
Call service technician, and open following link for some Bosch tankless resources including Bosch contact information:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 26, 2011 | Bosch PowerStar AE115 Tankless Water...
Stiebel eltron 12 the thermal breaker keeps popping. I'm an electrical engineer and understand that it's probably residual head left in the chamber when the water is shutting off that is causing the...
Hello; I can't clain any formal training or education in electrical, But, I am a home owner and Mechanic so I'll give this a try. Thermal switches are in the norm based on the bi- metal concept/ Automotive flashers are in essence thermal switches. Of course there are electronic types that contain points and a coil, we can forget those since we aren't doing a car or truck, let alone turn signal. OK, moving on. As you know,excessive continuous heat generated by a excess load will destroy the bi-metal strip which serves as a bridge in the circuit. A defective flasher will increase in speed as it gets older and used heavily. Anyway, to the point. I've experience thermal switches that cease to function if trip too often or were tripped by an excessive load. Although resettable initially, it's thermal tolerance gets shorter and shorter until eventually you get irritated enough to ask someone on Fix-ya for some input. No problem. I reccommend replacing the breaker with or of same amperes. You may want to verify the load by checking the appliance data plate just in case it's the straw the breaks the circuit I hope I helped you and I apologize for the analogy used. Thanks for using fix-ya. Good Luck _Ned_t
Apr 04, 2011 | Stiebel Eltron TEMPRA 12 Tankless Water...
Stiebel Eltron tankless 24. Problem:No hot water.Tempature display dead.Single LED on right side comes on when cold water flows thru system.Have cleaned fine mesh input filter.No pressure problems. CCt...
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Oct 11, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron TEMPRA 12 Tankless Water Heater Logo
319 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
