Question about Wolf Range Ovens
I have a 60-inch Wolf Range with 2 gas ovens below. One oven ignites and heats up. The other does not light at all. Red light comes on, but no ignition. Please advise.
  • Jim Morrissey Jan 11, 2013
    where is the glow unit in a 2009 Wolf Oven? Is it the small rectangular box on the "ceiling" inside of the oven?
  • 27 Answers
How old is it? model #?
Posted on Oct 26, 2013
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Roper gas range and oven with electric igniter
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 07, 2007
  • 306 Answers
SOURCE: THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Posted on Dec 03, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Posted on Feb 25, 2009
WRMtech
  • 70 Answers
SOURCE: ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Posted on Feb 26, 2009
I have a 30 inch wolf range I took the door off of. I'm trying to take the door apart but there are 2 screws behind the logo plate that need to come out. The problem I'm having is getting the logo plate...
A plastic putty knife can help, but the logo is held on with double sided tape and the Wolf parts book always says to order a new logo whenever you order anything that requires removing the logo
Aug 07, 2013 | Wolf Range WKGD-2 Gas Double Oven
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
Can't light ovens
good day,
hope this link below will solve your problem.
ovens
Mar 01, 2010 | Wolf Range WKGD-2 Gas Double Oven
Hotpoint lp gas range Mod# rgb532bea5wh. Oven will not light. Igniter does work but no gas is passing thru the oven control valve. I replaced the oven control valve but oven still does not work. what else...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective pressure regulator(likely issue if the igniter is ok)
Oct 23, 2009 | Hotpoint Ovens
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
How to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
Jan 16, 2009 | Wolf Range WKGD-2 Gas Double Oven
Ovens Logo
134 people viewed this question
Top Wolf Range Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
