Question about Maytag Neptune Washer Door Mah3000aww
Have an mah3000ww washer and it will go through the whole wash cycle but will not exspell water out of hose
    Master:
  • 452 Answers
Pump mite b blocked-filter on front machine or pump stopped working need to replace pump if filter is clear , to empty water out lay outlet pipe low down on floor and rain out so u can repair
Posted on Oct 19, 2013
Fix washing machine
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 31, 2015 | Admiral Washing Machines
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
TIMER
Mar 25, 2015 | Bosch Washing Machines
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washing machine will not drain the watere
CHECK PUMP/SEE IF ANYTHING STOPPING FROM PUMPING OR IT PUMP IS BAD,CHECK CLOGGED DISCHARGED HOSE ..
FRED
Feb 14, 2010 | Indesit W 123 Front Load Washer
My washing machine is a kenmore 70s the water wont come out when it exspells water. What could it be. thank you
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
If it won't drain but will spin, the problem points to either a bad pump or blocked hoses to/from the pump.
See the following for how to access and check the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=f628c3724b4c435a7770274972ee3861
Jan 05, 2010 | Kenmore Washing Machines
Washer tub won't empty even thoufh whole cycle done
you need to get the drain hose out and lower it into a bucket and let gravity do the rest, all the hose has to be lower than the water level in the machine though, and get the drain pump and sump checked out for blockages after.
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Maytag Neptune Washer Door Mah3000aww Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
