Question about Toshiba 56H80 56" Rear Projection Television
Screen Discoloration Problem
I cleaned a hard to remove spot off of the screen with a Mr Clean Magic Eraser and now there is a large discolored spot that won't go away. Do I need a new screen? If so is it easy to repair/replace? Does anyone know the part number for the screen? Can I fix it myself or do I need to hire someone to do it? Thanks.
  • 32 Answers
DJbsharp1: Check if the cleaner you use discolor or remove the clear of the screen. Touch the cleaned part and somewhere else on the screen to see if is rougher than the part you didn't clean-up. If this did not occur you can clean it up completely and watch the difference. If it's rough as I described you, a replacement will be necessary. It is easy to replace. Very easy. Part Number: 23430829 https://www.vancebaldwin.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=4003246&smodel=56H80 Click below to all the info and also for instructions on how to do-it-yourself with the service manual for FREE!!! Good Luck !!! https://www.vancebaldwin.com/shop/research_new/TBA/56H80.pdf SithPitt
Posted on Jul 04, 2007
SOURCE:
How can I remove coloured marks made by toys
Mr Clean magic eraser. Its a white sponge. It works.
Jun 02, 2014 | Villeroy & Boch Home
How to clean Black spots on baby swing
Use a Mr. Clean Magic Eraser. Best Wishes!
Jun 02, 2013 | Baby Care
What to use to clean the burner covers
You can clean them with a Mr. Clean eraser sponge. They cost about $5.00 for a package of two. You can use them with or without cleaning chemicals. They work great!
Mar 26, 2012 | Maytag MGR5752BD Gas Range
There is always a yellowish staining on the top part of the oven door, door handle and vents after self cleaning. I've tried bleach, sos, Mr. Clean Magic pads and it barely removes it. What do you...
the yellowish "staining" is a result of a bad seal. Since it is heat changing the color of the surface, you would probably have to do some damage to remove the discoloration, either like a soft abrasive scrub or other, bleach will not fix that.
Sounds like the cleaning cycle could be too long or otherwise too hot for too long? Perhaps a wipe down with a damp cloth to the interior of the oven prior to a self clean to remove any loose material may help.. Also if there are any other vents for this oven (say under one of the burners of the stove top) make sure they are kept free and clear of any blockage of air flow..
Best regards
Ck
Mar 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
How do I clean a baby G watch strap and face, it has dis-coloured!
hmmm once discolored I do not think there is a way really to get rid of discoloration , this is usually caused by sun shinning down on white and sort of bleaching it.
there is only two things that I know of that might be able to help.
1 is use a arm and hammer magic eraser on the watch face this is the safer of the two things.
2 is use a mild rubbing alcohol ( WARNING: THIS COULD DAMAGE YOUR WATCH FURTHER) I would start of by mixing half and half with water the alcohol in small cup and using it lightly on face to see if it discolors watch further. If not start rubbing and see if it helps remove some of the discoloration. if it does not add some more alcohol and test small area to see if it does any damage or not if not try it again . keep doing this , you might be able to use the alcohol with out water just depends. I would always test tout first though.
Oct 19, 2010 | Casio BabyG BG169WH 4AV Baby G Jelly...
I have a viking stove. Want to clean the steel on the burners. What would be the best product for this. They have some discoloration on them from spills . Thanks, Grace
Use a Magic Eraser sponge and get this cleaner called Star Clean(you buy it on the web from TJT products) it will have them looking like new.
Sep 04, 2010 | Viking 31 in. VGSU101 Gas Cooktop
Blackened spots on the ceran cook top's most frequently used burner will not come off, even with prescribed cleaner
Try using the Mr Clean Magic Eraser, it works well on most surfaces that other cleaners don't. Just be sure to follow the Mr Clean instructions and rinse out the sponge frequently and use it damp.
I've used this for cleaning just about everything, when everything else has failed. It's the neatest cleaning product I've seen in years.
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | Maytag MER5770 Electric Kitchen Range
Hitachi lcd projection tv screen discoloration model 50vs69a
probabally a dust spot on the mirror or the lcd mini panels inside the optical engine.
must be dissembeled to clean.
not for the faint of heart.
Jun 13, 2009 | Hitachi 50VS69 50" Projection HDTV
Aft self-cleaning, top of oven door and knob panel discolored
This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
Oct 24, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Can't remove burnt milk from right burner on stovetop?
I'm happy to say burnt milk can be removed with a combination of cerama bryte and let sit for one hour and then lots o elbow grease hard rubbling with also applying Mr. Clean Magic Eraser. The Mr. Clean Magic Eraser works very well but you have to still rub alot to get it safely scratch-free removed.
Dec 13, 2008 | Jenn-Air JED8430 Electric Cooktop
Toshiba 56H80 56" Rear Projection Television Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
