Question about Powerware PW3105 700 (103004248-5501) (1030042485501) UPS System
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
Pw3 10 specs
    Brigadier General:
  • 5,158 Answers
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Posted on Jan 22, 2009
    • Roberta Smith
      Roberta Smith Jan 22, 2009
      ok i stand corrected... you have posted in the ups catagory... what are the speakers ?
    I need to see a wiring diagram of an MPX 210 speaker box. My brother-in-law bought one from a friend and someone completely jacked the wiring. I just need to see how it should be wired. Pictures would be...
    It really depends on what subs you are mounting in the box. If you are mounting single voice coil subs, it's easy. positive of the sub goes to positive on the inside of the box and the negative of the sub goes to the negative of the box. Then you would repeat the process for the other sub. Then wire the box to the amp using the push or screw terminals.
    Now if you have dual voice coil subs, that's where it can get tricky. You really have to know what amp your using and what ohm load it can handle, and how many channels you will be using.
    I'm going to give you an example that has two dual 4 ohm voice coil subs. Let's assume you will be hooking them to a 2 channel amplifier that is 2 ohm stable.
    wire the positive of both voice coils to the positive post of the box. then wire both negatives of the voice coils to the negative of the box. Repeat the process with the other sub. This is called a parallel set up. Two 4 ohm voice coils wired this way will produce a 2 ohm load. since your amp is 2 channel, you will hook the positive and negative to the positive and negative of one side of the box, then repeat with the other channel to the other side. This will allow the most power to come out of a 2 ohm stable amplifier.
    If you have something other than the equipment I gave you an example of, repost with your equipment specs and I will walk you through it.
    Sep 09, 2011 | Dual QPower 10" Square Slot-Vented...
    Need to see how to hook up a single 10" kicker to an amplifier 600w so wont have issues down the line , also to get full use of speaker with this amp.
    Will need more specs on your equipment. Is the sub a dual voice coil? how many ohms per coil? Is your amp a single channel or 2 channel. Is it 2 ohm or 1 ohm stable? Post again with the info and I can help.
    Sep 03, 2011 | Car Audio & Video
    How to wire a 4ohm sub woffer to a 2ohm stable?
    First you need two 4 ohm speakers or one Dual voice coil speaker. you wire the speakers in parallel bringing the total impeadence to 2 ohms. The amplifier is what has to be 2 ohm stable...check your technical specs on the amp to see if its stable at 2 ohms...not all are. check this
    Jul 17, 2011 | Car Audio & Video
    I have two different sets of hook ups on my Power Aucoustik 10" Sub. Do I hook up both sides?
    Depending on the PA FUBAR you have. The voice coil on those subs are DVC. Dual Voice Coil. You need to know a couple things. What kind of amp are you going to run on it. And what is the resistance (OHM) rating of each voice coil. MY two 12's are dual 4 ohm. Meaning that there are essentially 4 speakers to hook up. My amp currently is not 2 ohm stable in bridged. So what I did is run each speaker in parallel (red2red,black2black) then run to the box terminal. So now the dual 4 ohm voice coils are basically 2 ohm. I have 2 speakers. Now I hook the box up in series. To bring the now two 2 ohm speakers into one 4 ohm speaker. This is called series/parallel setup. My amp sees this box as 1 channel @ 4ohms. The downfall to this is the output of the amp is divided up into each speaker. So instead of sending all 1400 watts to one sub. I will send 700 to each sub. But here is a catch. even though each speaker is half the total wattage it will still be 3db louder. Meaning it will be as loud as 1 sub running 1400 watts. To conclude i need to know how many of those subs you are going to run on the amp.. And the model number of the amp so I can match up your wiring.
    Jun 06, 2011 | Power Acoustik FUBAR-12W Car Subwoofer
    How do I wire up my jbl w12 to positive an negative
    Hi Adrian,
    To be honest, it depends on your amp, also on whether this is a dual voice coil sub or a single.
    As a rule, if the sub has a dual voice coil (2 sets of connections) then connect the 2 positives together and the 2 negatives and run the 2 sets of cables to one output on the amp.
    Check your amp specs to make sure that it will run @ 2 Ohms as this is what will result.
    If your amp isn't 2 Ohms stable then you will have to wire each voice coil to a separate output on the amp.
    May 08, 2011 | JBL Car Audio & Video
    I have no idea what to do with my panzer maxp124d subwoofer. There's like 8 terminals on each sub and idk how to wire them
    Here are the specs for your speaker.
  • Dual 4 Ohms Nom. Impedance
  • Fs: 40Hz, Qms:5.0, Qes: 0.90, Qts: 0.75, SPL: 84(dB), Vas: 5.204(Cuft)
  • That should help you design a good box.
  • The eight terminals are actually 4 with double slide ons for each. Each side has a + (positive)
    and a - (negative) with 2 connectors at each connection point.
    It is a dual voice coil thus 2 sets of inputs.
    If you have a 4 ohm amplifier then you are ready to go with a left to one side's terminal and a right amp output going to the other. If you have 2 speakers this can get wild because you can run them in parallel
    or series and reduce the impedance to 2 ohms if your amp is 2 ohm stable. If not-dont do it!
    You will burn the amp up. See #58 on the right sidebar of this site. It will teach you how to get the most
    from your setup. Bookmark the site. It has every kind of knowledge you need for audio or electricity.
    Look for the DVC (dual voice coil) info.
    "The image below shows the DVC speaker wired to both channels of a stereo amplifier. Each channel of the amplifier drives a 4 ohm load. " This looks like what you have to do.
    http://www.bcae1.com/
    Mar 15, 2011 | Lanzar MAXP124D Car Speaker
    My kicker still pounds a lil bit but not lie it used to i think i dropped the ohms too much what do you thik the problem is
    It has to do with Ohm rating along with what your power amp specs are. If you are wired to have this dual voice coil speaker for 2 ohms (parallel), then your power amp might not perform, or able to handle the 2 ohm load, and therefore might go into thermal overload/protection. If you are wired to have this dual voice coil speaker for 8 ohms (in series), then your power amp will not put out the wattage it is rated for, or be able to "push" it at all. The higher the ohm load, the less wattage output from amp, especially if the amp is made to work at 2, or 4 ohm load. Check your specs.
    Apr 26, 2010 | Kicker CVR15-4 Car Subwoofer
    I got two DUAL 2omn speakers and i just need to know best way to wire them for a mono block amp. i have them wired parrallel in the box
    With 2 speakers wired in parallel, the impedance will be halved, so you are presenting a 1 ohm load to your amp.
    Many amps can drive a 1 ohm load, but not all of them. Check the specs for your amp.
    If it can't drive a 1 ohm, then you'll need to rewire them in series. 2 speakers wired in series will double the impedance, so you'll present a 4 ohm load when they're wired that way.
    Jan 29, 2010 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
    Im trying to find RMS specs for PERFORMANCE TEKNIQUE CBM-5712 SUB
    WELL FIRST IF THEY ARE DUAL VOICE COILS, IF SO,TO GET 2 OHMS JUS THOOK THEM UP TO ONE OF THE TWO TERMINALS, IF YOU WANT 4 OHMS HOOK YOUR POWER LEAD TO ONE TERMINAL THEN ABOUT THREE FEET OF WIRE COMING FROM YOUR LEAD TO THE O9THER TERMINAL, IF YOU WANT 8 OHMSHOOK YOUR POWER LEAD TO + ON ONE SIDE THEN THE NEGITIVE LEAD TO THE - ON THE OTHER SIDE, THEN VISE VERSA. BUT IF I WHERE YOU MAKE THEM 4 OHMS
    GOOD LUCK
    Dec 12, 2008 | Performance Teknique ICBM-5712 Car...
    Powerware PW3105 700 (103004248-5501) (1030042485501) UPS System Logo
    155 people viewed this question
    Top Powerware Computers & Internet Experts
    Vassilis Chamaidis
    Level 1 Expert
    Jax Planet
    Jax Planet
    Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
