Question about Clerc Eai Colt 290 Stopwatch Transparent Clear
Eai colt 290 instructions - Clerc Eai Colt 290 Stopwatch Transparent Clear
Extra link 823a
This person wasn't asking for advice about buying a rubber wrist strap for a diving watch, but rather was asking about where to get an extra link for the watches stainless steel bracelet1
Jun 12, 2012 | Breitling Aeromarine Colt Auto / Colt...
I don't know how to change the date on my breitling colt
Their web site does not give any user manuals but most watches change the date by pulling out the crown to position 2 (1 is the normal home position, 3 is fully out and 2 is inbetween the two) and rotate the crown to change date.
This quality of watch may require you to turn the crown wheel anticlockwise before pulling it out (extra seal).
If this does not work them go to http://www.breitling.com/en/index.php#/models/aeromarine/chrono-colt/ and using the menu on the left, locate their nearest service center and contact them. I fell sure that they will be only too happy to explain the procedure for changing the date.
Dec 13, 2010 | Breitling Colt GMT 293/BL/FGHT Wrist Watch
I have a bretling colt quartz watch and the hour regester will not reset
Try pulling out the winding crown,then press the chrono pusher.This will advance the chrono hands.Each pusher will advance a different hand.
Aug 13, 2010 | Breitling Colt Quartz 820 Wrist Watch
Brieting Colt chronograph - 12 hour timer will not reset to zero.
The chrono hands can be set by pulling out the crown as if the date or time was to be set.With the crown out press the chrono pushers to advance individual hands as required.
Regards
Aug 05, 2010 | Breitling Colt GMT 292/SLV/FGHT Wrist...
Is 6 seonds to fast for a breilting colt to be running
Although this is poor compared to electronic watches, I have read other makers accuracy claims and they say that a mechanical watchcan be out by as much as 20 seconds a day!
I would have thought that it could be regulated (adjusted) to run more accurately but you will have to speak to the manufacturer about this.
Jun 07, 2010 | Breitling Colt Automatic 905...
Breitling Colt Kinetic Watch - not working
I read the instructions for a similar type of watch and while the battery will keep the watch "alive" for some months when not in use, eventually the battery dies.
Since it is a kinetic watch the instructions I read said that you should gently shake the watch about 500 times to recharge the battery!
If you give it a good shake and then wear it for a few days, it should recharge itself, although it may have forgotten the time and may need re-setting.
Mar 01, 2010 | Breitling Colt Oceane 504 Watch
How can i replace the battery on a Breitling
I suggest that you got to "www.breitling.com" and after getting past the pretty pictures you click on "maintenance centers" and find the one nearest you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
One fairly frequent cry for help is because the owner can't get the back on again. Also since watches frequently include gaskets to keep water out, difficulty can be experienced in fitting the back and maintaining the seal.
Feb 17, 2010 | Breitling Aeromarine Colt Ocean A64350...
Where can I get an instruction manual for my Breitling Watch?
You can't. At least not with out some effort. Breitling is paranoid about rip-offs.By that I mean someone gets an original manual and boxes it with a fake breitling and.....WA LA.....rip-off.
The best way to get one is click the link below and locate a service center nearest you and get it though them.
Most owners won't part with theirs and they are difficult to scan so it's about your best/only option.
Good choice by the way I don't know what model you have but I love my Colt Chrono.
Hope this helps.
http://www.breitling.com/en/index.php#/contact/
Dec 31, 2009 | Breitling Watches
Operating instructions for breitling wrist watch
You won't generally find these on line.
Your best bet is a visit to your local Authorised Dealer or contact Breitling UK fo a manual.
Dec 23, 2009 | Breitling Colt GMT 292/SLV/FGHT Wrist...
Clerc Eai Colt 290 Stopwatch Transparent Clear Logo
127 people viewed this question
Top Clerc Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Clerc Watch Expert? Answer questions, earn points and help others
