Question about Dishwashers
Bush dishwasher is turned on but the button does not work on plans for a wash
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Posted on Jan 12, 2013
I don't know which are the soak and strong buttons on my bush dishwasher can you tell me ?
Tell me the model and I should be able to find your manual.
Click COMMENT under my post.
Have a look at the video reviews. I trust you did mean 'BUSH' and not 'BOSCH'?
Bush Dishwasher Review - DWFS146W White Full Size Bush ...
? 7:56
https://www.youtube.com/watch?v=BF2eEiS9sCs
Oct 10, 2015 - Uploaded by MyReviews
Before you consider buying a Bush dishwasher DWFS146W from Argos or Homebase, watch my review first ...
Bush Intergrated Dishwasher Review - YouTube
? 2:05
https://www.youtube.com/watch?v=byDitRlbKzQ
Jun 30, 2014 - Uploaded by Midlands Family
This is my Bush Intergrated Dishwasher review. Please like & subscribe to my YouTube channel.
bush dishwasher Google Search
Aug 01, 2017 | Bush Dishwashers
Just bought a Bush dishwasher and can't do plates because the paddle hits them...is this normal?
In some dishwashers, you can raise or lower the upper rack to make room for taller plates or taller glasses. In others, there is no adjustment, and you're stuck - you've got to buy smaller plates!
Sep 18, 2014 | Bush Dishwashers
Instruction manual for bush wv12-75dw
Can't find user manual for bush dishwasher Bush Dishwasher WV12-75D
Jan 15, 2013 | Dishwashers
Dishwasher over filling
try connecting the the hot water rather than the cold. I had this problem before when i only had a cold water feed. to get round it i poured some boiling water in first , left it for about 30 seconds then started the wash cycle
Jun 30, 2012 | Bush DW5F 22 in. Dishwasher
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
Dishwasher makes a whinning noise during the washing cycle. I have opened to check inside, and the dishwasher is ok for a few minutes, then it starts whinning again. The dishwasher is just over a year old,...
If wash quality is OK leave it. Pump will make whining noise due to its' ball/bush bearing problem.
Some times if the water inlet flow is not free in flow also results in noise.
Clean the inlet water filter and check the flow before re- connecting to the machine.
Aug 30, 2010 | Dishwashers
CONIA DISHWASHER CDW1211 -Thelittle door that
i find it hard to get parts for these because the are imported from china.it may be better to replace the dishwasher
Jun 08, 2010 | Dishwashers
Bottom Washer Arm Problem
Hi Karen P The bottom arm ( well all arms really)is rotated by the water pressure created by the main pump. The bottom arm should spin freely when rotated by hand. If not, then the bush (or plastic bearing) may be worn or sticking. These parts are fairly inexpensive (at worst a new bottom arm will be required). Contact your local Maytag spares supplier and ask for a Bush repair kit for the bottom arm of your model. Regards
Aug 20, 2007 | Maytag DWU9962 Dishwasher
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Owen Barnes
