Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby g2000 no power
My Kirby g2000 will not power up or turn on.
  • Kirby Master
  • 18,394 Answers
This video should help you
Posted on Jan 12, 2013
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: G2000 Kirby HELP
I'm not familiar with this type of vacuum, but if it's like most kirby's the powerhead gets all its motion off the tapered spindle underneath the powerhead. IF the belt is installed backwards on this spindle then all motions are reversed. there should be an arrow stamped into the blower housing. the belt should be installed so it is nearest to the arrow in the direction of the arrow on the housing.
Posted on Aug 24, 2007
b0sslady2001
  • 357 Answers
SOURCE: Kirby won't turn on only when trying to use power nozzle
Make sure that your power nozzle has a little metal prong that plugs into the little rectangular hole in the fan case. If the prong is broken, you'll need a new nozzle. If the prong is intact, you'll need a new switch. Here is a link to help with the repair and help you locate the switch.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps!
Posted on Aug 28, 2008
b0sslady2001
  • 357 Answers
SOURCE: Kirby g2000 shampooer
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Here is the instruction guide for the shampooer also. Hope this helps...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Posted on Jun 28, 2009
  • 85 Answers
SOURCE: Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Posted on Dec 18, 2009
Kirby G2000 how do you get the head off to check for clogs
HI Linda,
The G2000 kirby is the same procedure as the G5 Kirby. As it happens I put a solution up on YouTube showing how to change the belt and to do this you need to take the head off. Long story short if you watch my video you will see how to take the head off. If you need anything for your Kirby like kirby bags or kirby Belts just visit VacuumSpot
Dec 03, 2012 | Vacuums
Kirby g4 stoped working
cable has shorted out internally, will need new cable
Nov 18, 2012 | Kirby G4 Bagged Upright Vacuum
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
I would check to make sure he put the filter bag in correctly.
Dec 16, 2009 | Vacuums
Replacing fan assembly on Kirby G2000
this video should get you half way there:
Kirby belt replacement
Hope it helps
Sep 15, 2009 | Vacuums
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Marci
Jun 10, 2009 | Kirby G6 Bagged Upright Vacuum
Hope this helps!
Aug 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vibrating and noisy Kirby
Power off the vacuum.
Unplug the power cord from the wall.
Remove the head or hose attachment.
Look at the fan and make sure all the fins on the fan are there.
If part of one or more is missing it will cause the fan to wobble and shake.
Oct 18, 2007 | Kirby G4 Bagged Upright Vacuum
G2000 Kirby HELP
Aug 22, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
57 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
