Question about Philips DC291/37 Docking Clock Radio For iPod / iPhone / iPad - REFURBISHED
Manual for DC291/37 Aluminum Iphone/Ipos/Ipad dock station
Just trying to obtain manual
  • Max Wilson Jan 11, 2013
    I would like to download a owners manual for the above Philips Docking Station
3 Suggested Answers
  • 43 Answers
SOURCE: I have a Philips
You didn't give a dock station model number, but I'll assume it has RCA (round red and white outputs). Connect the wire from the back of the dock to the preferred (red and white) input on your receiver. Change the channel on your receiver and you're set. Good luck!
Posted on Jun 13, 2011
SOURCE: why wont iphone communicate with the ipod station
Have you made sure that there is no protective case on your iPhone that would be interrupting the connection between the two devices? Have you verified that your device is compatible with the dock? On most of the new ones they require a digital input from the iPod/iPhone which only iPods made in the past few years (2007 or later) can supply. Also try docking your device when the docking station is in standby mode.
Posted on Dec 25, 2011
Change dock connector
Though I'm not sure, I think what you are asking is how to use an iPhone 5s on an older iPhone docking station. If so, my recommendation is to buy and a 30 pin to 8 pin adapter. Here is an example:
http://phonepartsusa.com/adapter-30-pin-to-8-piniphone-5-ipad-4-ad?language=en₪cy=USD&gclid=CJbTm_u188MCFUZhfgodt2wA9Q
Apple sells one as well called a Lightning to 30-pin Adapter for about $30. Here is that link: http://store.apple.com/us/product/MD823ZM/A/lightning-to-30-pin-adapter
It all depends on the form factor of your dock and whether the added size of the adapter will still allow your phone to sit on the dock. There may be some smaller, slimmer ones. If the phone doesn't fit on the dock with the adapter in place, you could also buy a iPhone 5s extension cable and just cable your phone to the dock and adapter.
Feb 21, 2015 | Apple iPhone 4S
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
I have a new docking stationbut am unable to connect it to my old apple ipod canyou help please
Probably your new docking station is equipped with the new Lightning connector used by iPhones and iPads instead of the 30-pin connector used by old and newer iPods. Search on Internet to see if you can find a Lightning-to-30-pin adapter. Do not get a 30-pin-to-Lightning adapter; you will waste your money.The latter adapter is more readily available, but is used to connect an iPhone or iPad to and OLDER docking station equipped with a 30-pin connector.
Dec 25, 2014 | Apple Audio Players & Recorders
My Sony audio charging station will not charge my iPad ,it worked for a year but not now
method 1 ) dock your ipad and then turn on Power for sony station
Method 2 ) dock to already powered station
Either one should work. Else refer to manual trouble shooting section.
Jul 20, 2014 | Sony Rdpt50ip Ipad[r]/iphone[r]/ipod[r]...
IPod/Line In button ineffective. Can't listen to music, videos, etc. Help me! If it makes any difference, I have an iPhone 4.
Good Morning
I also have an iPhone 4 and when I bought my docking station I had exactly the same problem, it turned out that the device was faulty and I took it back to the shop, try that or check the manual if you docking station supports that function
Nov 30, 2012 | Audio Players & Recorders
Sony dock not working after iOS 6 update? Just says not an apple compatible product?? Any idea of an update or a fix on the way?
My wife had this problem with iPhone 4S after updating to ios6 on a Sony xdr-ds12ip docking station. Sound would play on iPhone off the docking station, but once it was docked no sound would come through the docking station speakers (docking station radio works fine, as did the iPhone before the iOS update). Fixed it by powering down both the iPhone and the docking station at the mains, gave it 2-3 minutes and then powered on the docking station and then the phone. Placed the iPhone in the docking station and voila the sound comes out of the speakers now.
Sep 29, 2012 | Audio Players & Recorders
Ipod docking station, piece broken off and it wont detect ipod
How to remove fix broken Apple Ipod Touch 4Th Gen A1367 Dock Connector
I would enquire regarding repair at: e-mail: info@i-Luv.com
The manual for your docking station should on its last page have contact information. I obtained the above email out of an online manual. This information is challenging to obtain. I hope what I have provided gives you some idea of what is involved.
Sep 05, 2017 | Audio Players & Recorders
Why wont iphone communicate with the ipod station
Dec 25, 2011 | Philips DCM250 Table Stereo Clock Radio...
I pod charges, plays, but no sound
Easy, I had this problem too. The reason it isn't playing is because its not in all the way. I was getting very frustrated with this, so I kept trying to push it onto the dock to get it all the way down.
Solution:
1. Play a song on your ipod/iphone so you can hear it through the device.
2. Connect your ipod/iphone to the docking station(Bose) so that you hear the chime(This lets you know its charging).
3. Pick up the docking station and firmly press the ipod/iphone down on the connector.
4. Keep pressing it and wiggling around until you hear the music begin to play through the docking station.
It may take a few tries, but you will get it.
Hope this helped!
~ Jake
Oct 05, 2009 | Bose SoundDock digital music system...
Philips DC291/37 Docking Clock Radio For iPod / iPhone / iPad - REFURBISHED Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
