Question about Dishwashers
Locked and cannot get it to release
  • 17,130 Answers
Check this link : Door lock
Posted on Jan 12, 2013
Fuel door won't open on a 2008 g8 pontiac
Fuel Fill Door Description and Operation
The fuel door latch actuator shares the circuit with the driver door latch assembly. The body control module (BCM), upon receipt of a lock switch lock or unlock signal, will switch the appropriate door lock actuator, as well as a fuel filler door release actuator control circuits to battery positive voltage. The opposing side of the door lock and fuel filler door release actuators is connected to ground by the I/P fuse block through the other door lock actuator control circuit and the doors, along with the fuel filler door release, will lock or unlock as commanded.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the fuel door release actuator.
  2. Test for less than 1 ohm between the control circuit terminal 1 and ground.
  3. ?‡'
    If greater than the specified range, test the control circuit for a short to voltage or an open/high resistance.
  4. Test for less than 1 ohm between the control circuit terminal 2 and ground.
  5. ?‡'
  6. Connect a test lamp between the control circuit terminal 1 and control circuit terminal 2.
  7. Ignition ON, command the doors to LOCK and UNLOCK by using the door lock switch. The test lamp should illuminate while commanding the LOCK and UNLOCK states.
  8. ?‡'
    If the test lamp remains OFF during either command, test either control circuit for a short to ground.
  9. If all circuits test normal, test or replace the fuel door release actuator.
Component Testing
  2. Install a 15A fused jumper wire between the control terminal 1 and 12V. Momentarily install a jumper wire between the control terminal 2 and ground. The fuel door release actuator should perform the LOCK/UNLOCK function.
  3. ?‡'
    If the function does not perform as specified, replace the fuel door release actuator.
  4. Reverse the jumper wires. The fuel door release actuator should perform the UNLOCK/LOCK function.
Remove the rear compartment side trim (right) panel. Refer to
Rear Compartment Side Trim Panel Replacement .
Apr 06, 2016 | Pontiac Cars & Trucks
Lock cylinder removal from knob
remove lock from door , remove spindle from center of lock by center spindle then depressing release and remove spindle ( release is spring loaded at base of spindle , insert a flat peace of 1/2 " wide metal with a V shape at the end , , push the metal I to the lock and release the lock . it may have to be taped in until the lock falls out,
Jun 09, 2015 | Kwikset Locks & Locksmithing
Machine Lock Button Release Lever Issues
If you are trying to release the looper back for threading, the loopers have to be in a certain position, otherwise they will not release.Usually, the looper must be in the farthest position to the right, then they should be able to release.
Jan 26, 2014 | Baby Lock Imagine
Shift lock release
There should two brake switches located above the brake petal, one is designed to activate the rear brake lamp relay, the second would be the park/neutral safety switch which may be defective and failing to activate the shift handle release relay. You can test this by first turn the ignition key forward then jump the two wires behind the switch, you should then hear the transmission shift handle lock release. If this is heard, the switch has failed and requires replacement.
Dec 22, 2013 | 2008 Honda Civic
Gear release lock on Cub Cadet GT1225
Does the unit function ( tranny ) normally otherwise? If not, then the tranny is locked. You have broken a gear tooth at a minimum in the tranny and it is locking the tranny gears.
Jul 05, 2013 | Garden
2002 Hyundai Elantra Drivers dorr Lock Jammed not unlocking properly. Lock lever on inside and key on outside are stuck and door move bery much and will not unlock car. Originally cable in door to release...
Same thing happened with mine. It turned out that the power door lock motor went out. Since the handle or the switch can unlock the driver's door, both of these mechanisms are connected. When the door lock motor goes out it freezes in whatever position, it was last engaged.
Nov 06, 2010 | Hyundai Motor 2002 Elantra
Lock release broken
Replacing the lock release is a major repair, because the entire projector has to be dis-assembled in order to get to the release from the inside. It very well may be cheaper for you to buy a used projector online.
Mar 27, 2010 | Kodak Carousel 4400 Slide Projector
The trunk will not open when you pull the lever
this trunk is designed that there a position of the trunk lock that locks that inside handle,some car also use a lever at the latch to disable the inside trunk release,im 1 sure this car uses the trunk lock, take a look and see if you lock out the inside release. if the lock window where you put the key in is pointing at 3 or 9 oclock then its locked the inside release if its at 12 or 6 oclock then the inside release should work and then the cable may be bad, good luck.
Feb 20, 2010 | 2000 Nissan Altima
Ra ascenntion lock release does not release
Contact Orion customer service:
http://www.telescope.com/control/main/
Oct 23, 2008 | Orion SkyView Pro 100mm ED EQ Apo...
Dishwashers Logo
Top Dishwashers Experts
