Question about Jabra GN9330 Wireless Headset
The mute beeps every couple of seconds. how can I keep staying in mute and cancel this beep?
I tried muting it either from headset or from Lync it is teh same
Error message
Very possibly a computer component is failing or has failed.
Sep 12, 2016 | Sewing Machines
Nokia bh 202
Fully charge the headset, disconnect the power supply cable, and at the same time press power/call multifunction key and volume up for about 8 seconds. It will reset the headphones and the led flashed red and blue. Turn it on and re-pair the headset and mobile. It will resolve the problem. Nokia Bluetooth Headset BH 504 is not working
Apr 16, 2017 | Radio Communications
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
May 19, 2011 | Plantronics CS70 Wireless Headset
I'm trying to recharge my headset but the green light remains on (I clicked on the botton on the headset piece but it won't turn off). When I try to turn it off, it beeps at me
try doing a system reset press the call control button and the volume mute button at the same time for 5 seconds. when the talk indicator light blinks release both buttons. press the call control button again and the talk indicator light will blink again briefly headset is back to normal then unplug the charger from the charging jack for 5 seconds and plug back in headset is reset. if that doesnt work then replace the battery in headset.
May 05, 2011 | Plantronics CS55 Wireless Headset
When i try to talk threw my headset the other person cant hear me but i can hear my self talk on it
Could be that the headset has been muted by accident. To unmute, tap both volume buttons at the same time until you hear a tone or kind of beep.
Jan 08, 2010 | Motorola Mobility H710 Bluetooth Headset
Hfb300
turn the unit on using the large button that has a phone on it. once the unit is on then put your phone into "pairing mode" (see phone instructions for how to do this) and then hold the "mute/function" button for up to 10 seconds until it beeps and the blue light flashes on and off every one second. then your phone will discover the unit and ask for the passcode which is 0000, enter this on your phone and the pairing will complete with a beep from the HFB-300. the unit will pair up to 3 phones in the same way and will only recognise 1 phone that is on at once so you need to only switch bluetooth on for one phone at a time. if you pair more than 3 phones then the unit will automatically drop the oldest existing one it already has stores
Apr 21, 2008 | LG BLUETOOTH? HFB-300 NOISE CANCELING...
No voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
LG BLUETOOTH HFB-300 connection problem
Oct 29, 2007 | LG BLUETOOTH? HFB-300 NOISE CANCELING...
H700 headset can't hear me!
Push both volume buttons at once to turn Mute off. You should hear two beeps, ascending in pitch to indicate mute is off. If they go down in pitch mute is being turned on.
May 09, 2007 | Motorola Mobility H700 Wireless Headset
Jabra GN9330 Wireless Headset Logo
278 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
